Can FRDM-KW41Z implement A2DP connection to a Bluetooth headset?
simonxian
Hi, can FRDM-KW41Z be used to implement A2DP connection to a Bluetooth headset? Are there any software examples  for reference?
Thanks.
Tags (2)
stephanie_m
Sorry for the inconvenience this might cause you but it does not support it.
The KW41 supports BLE 4.2 and the A2DP it’s a Bluetooth classic profile.
Estephania
simonxian
  So, the KW41Z can't be used to communicate with the  headset of bluetooth classic, and it is not compatible with HFP(Hands-free Profile) either, is it right?
Thanks a lot.
stephanie_m
You are right, and the reason why is because BLE is not intended to be used for audio streaming; it has the sleeping times to be low power and the packet size tend to be small.
Sorry for the inconvenience this might cause you.
Estephania
simonxian
I see.
Thank you very much for your kind reply.
