Beginner on KL15, where to begin?
markosiponen
Hello
I have previously worked with STM32 (Cortex M3 from ST).
Now I must learn how to use an KL15. Where do I begin learning the KL15? Where can I find the best code examples and training material?
I have ordered a FRDM-KL25Z to start testing my code.
Is there a peripheral driver library available for this MCU? Or do I have to write all peripheral setup functions by myself (ST have a great peripheral driver library for their STM32 series)?
Tags (2)
vivacious
You may like to start with some sample codes done for you. (look for "KL25_SC.exe".....in the "download" tab for the board)
If you are on IAR...then it's lot better but not to worry even if you are CW.
Good luck!!
vivacious
Good luck!!
