Basic and main differences between the KL05Z and KL25Z boards
2,974 次查看
alexandrecrt
What are the basic and main differences between the KL05Z and KL25Z boards? In terms of programming, are these boards compatible? I have a KL05Z card and I intend to buy a KL25Z.
标记 (2)
2,847 次查看
kerryzhou
Hi Alexandre Cesar,
   About the detail difference between the KL25 and KL05, you can check this document:
https://www.nxp.com/docs/en/product-selector-guide/KINETISLMCUSELGD.pdf
  Just some peripheral difference, the clock module also have different, the KL05 just have FLL module, don't have PLL module, the package also not the same, it is not the pin to pin compatible.
  But don't worry, the programming item is totally the same.
Wish it helps you!
f you still have question about it, please kindly let me know.
Kerry
2,848 次查看
kerryzhou
Hi Alexandre Cesar,
Wish it helps you!
Kerry
2,847 次查看
alexandrecrt
Thank you, very much.
Have a nice day.
Em sex, 17 de mai de 2019 às 04:13, kerryzhou <[email protected]>
escreveu:
NXP Community
<https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
Re: Basic and main differences between the KL05Z and KL25Z boards
reply from Kerry Zhou
<https://community.nxp.com/people/kerryzhou?et=watches.email.thread> in *Kinetis
Microcontrollers* - View the full discussion
<https://community.nxp.com/message/1152919?commentID=1152919&et=watches.email.thread#comment-1152919>
2,847 次查看
kerryzhou
Hi Alexandre Cesar,
   You are welcome!
  If your question is solved, please help  to mark the correct answer, just to close this case, thank you!
Kerry
