BLE 5.1 in NXP products?
2,772 次查看
trialaccount12
Contributor V
         I am working on an independent project where as I am using Ble 5.1. I checked NXP products whereas I could find only 5.0 version. Is there any products which supports 5.1 or would be there be any software update to use 5.1 in existing products?
Thanks and Regards
Niranjan
标记 (3)
2,446 次查看
stephanie_m
Sorry for the inconvenience this might cause you, but those are currently all the Bluetooth Le IC's that we have available.
You can find our complete list of Bluetooth LE solutions in this link.
Estephania
2,446 次查看
trialaccount12
Contributor V
    Thank you. I also do have an additional question. Is there anyways to determine the postion of an object in terms of x,y and z axis using ble 5.0?
Any approaches would be helpful.
Thanks and Regards
Niranjan
2,446 次查看
stephanie_m
I believe something like this thread it's what you are looking for. Still, if it does, there is a lot of lecture needed in order to create such algorithms as we only provide some IQ captures API's and the rest of the implementations it's upon every customer.
Estephania
