As a part of our Obsolescence analysis of our existing product, we need the 1. Part status (Active / Obsolete), 2. PCN (If any) and 3. 'End of life' (EOL) information (If any) - for the following part, Manufac
908 次查看
pragathigolcond
Manufacturer part number: 1) MK61FN1M0VMJ12@ (/R) (Description: K61 Processor  (OTP/CPU)) ,
                                            2) MK60DN512ZVMD10   (Description: K60 Processor (CIQ3)).
Kindly refer proper channel or right person, who shall support in this regarding.
Kindly revert back, if you need any other information.
832 次查看
Kan_Li
Hi PRAGATHI GOLCONDA,
Please check with your local DFAE for such kind of info, and you may find the contact info from the following link:
Distributor Network|NXP
Alternatively you may send a support request via the following link:
http://nxpcommunity.force.com/community/CommunityContextPage
Hope that helps,
Kan
