Advertisement message length
kevin_lang
I am using KW41Z, currently I can only send 31 bytes advertisement message, is it possible to increase it to about 200 bytes?
Thanks in advance,
Kevin
stephanie_m
The advertisement data can be up to 31 bytes as defined in the Bluetooth LE specification.
Sorry for the inconvenience this might cause you.
Estephania
kevin_lang
Thank you Estephania,
One more question , can KW41Z BLE support 2 connections concurrently?
Kevin
stephanie_m
As stated in the Data Sheet the KW41Z supports up to 2 simultaneous hardware connections.
