AFE Sigma-Delta Channel Mapping and Multi-Phase Input Support on TWR-KM35Z75M (Metering Library)
Anusudhan06
Hello NXP Team,
I am working on TWR-KM35Z75M using the latest MCUXpresso SDK and evaluating the Metering Library with the MKM35Z512 AFE (24-bit Sigma-Delta ADC). I need clarification on how the AFE channels are configured and how the metering library acquires samples.
  • SDK: Latest MCUXpresso SDK release for KM35
  • MCU: MKM35Z512VLQ7 (Kinetis-M series)
1. The metering examples (meterlib1ph_test, meterlib3ph_test) never explicitly reference these pins and need to know exactly where in the SDK the AFE channel-to-signal mapping is configured.
2. Actual AFE sampling rate (Hz / kHz), Whether sampling is triggered internally or by a timer, Whether samples are transferred via DMA, interrupt, or internal FIFO
3. I need to connect three-phase voltage and current signals to the board. What is the recommended channel assignment for 3-phase V/I pairs?
carlos_o
Hi @Anusudhan06
Thanks for your post,
There same some Application Notes related to your questions please review it:
Using the FFT on Sigma-Delta ADCs
Kinetis-M Two-Phase Power Meter - Reference Design
Filter-Based Algorithm for Metering Applications
carlos_o
Hi @Anusudhan06
Anusudhan06
Thank you @carlos_o
I am currently integrating the Analog Front-End (AFE) configuration with the Metering Library in my project and would greatly appreciate it if you could provide a reference example.
I have already referred to the provided example file, meteringlib3Ph_test.c, which clearly shows how to use the Metering Library APIs.
However, We would greatly appreciate it, If you could provide a more complete reference example that explicitly demonstrates the integration of both the AFE configuration and the Metering Library together.
  • Initialization Sequence: The correct order and method for initializing both the AFE and the Metering Library.
  • Data Flow: How the raw AFE data is captured, formatted, and correctly passed as input to the Metering Library functions.
Thank you for your consideration of this request.
Anusudhan06
I’m circling back to see if you’ve had a chance to look into my request yet.
%3CLINGO-SUB%20id%3D%22lingo-sub-2260220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAFE%20Sigma-Delta%20Channel%20Mapping%20and%20Multi-Phase%20Input%20Support%20on%20TWR-KM35Z75M%20(Metering%20Library)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20NXP%20Team%2C%3C%2FP%3E%3CP%3EI%20am%20working%20on%20%3CSTRONG%3ETWR-KM35Z75M%3C%2FSTRONG%3E%20using%20the%20%3CSTRONG%3Elatest%20MCUXpresso%20SDK%3C%2FSTRONG%3E%20and%20evaluating%20the%20%3CSTRONG%3EMetering%20Library%3C%2FSTRONG%3E%20with%20the%20MKM35Z512%20AFE%20(24-bit%20Sigma-Delta%20ADC).%20I%20need%20clarification%20on%20how%20the%20AFE%20channels%20are%20configured%20and%20how%20the%20metering%20library%20acquires%20samples.%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ESDK%3A%20%3CSTRONG%3ELatest%20MCUXpresso%20SDK%20release%20for%20KM35%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EMCU%3A%20%3CSTRONG%3EMKM35Z512VLQ7%3C%2FSTRONG%3E%20(Kinetis-M%20series)%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E1.%20The%20metering%20examples%20(meterlib1ph_test%2C%20meterlib3ph_test)%20never%20explicitly%20reference%20these%20pins%20and%20need%20to%20know%20%3CSTRONG%3Eexactly%20where%20in%20the%20SDK%3C%2FSTRONG%3E%20the%20AFE%20channel-to-signal%20mapping%20is%20configured.%3CBR%20%2F%3E2.%26nbsp%3BActual%20%3CSTRONG%3EAFE%20sampling%20rate%3C%2FSTRONG%3E%20(Hz%20%2F%20kHz)%2C%26nbsp%3BWhether%20sampling%20is%20triggered%20internally%20or%20by%20a%20timer%2C%26nbsp%3BWhether%20samples%20are%20transferred%20via%20%3CSTRONG%3EDMA%3C%2FSTRONG%3E%2C%20interrupt%2C%20or%20internal%20FIFO%3C%2FP%3E%3CP%3E3.%26nbsp%3BI%20need%20to%20connect%20%3CSTRONG%3Ethree-phase%20voltage%20and%20current%20signals%3C%2FSTRONG%3E%20to%20the%20board.%20What%20is%20the%20recommended%20channel%20assignment%20for%20%3CSTRONG%3E3-phase%20V%2FI%20pairs%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId-2003225495%22%20id%3D%22toc-hId-2003255233%22%20id%3D%22toc-hId-2003255233%22%20id%3D%22toc-hId-2003255233%22%3E%26nbsp%3B%3C%2FH3%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2260427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AFE%20Sigma-Delta%20Channel%20Mapping%20and%20Multi-Phase%20Input%20Support%20on%20TWR-KM35Z75M%20(Metering%20Library)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257895%22%20target%3D%22_blank%22%3E%40Anusudhan06%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThere%20same%20some%20Application%20Notes%20related%20to%20your%20questions%20please%20review%20it%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4847.pdf%3FWT_ASSET%3DDocumentation%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EUsing%20the%20FFT%20on%20Sigma-Delta%20ADCs%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FDRM149.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EKinetis-M%20Two-Phase%20Power%20Meter%20-%20Reference%20Design%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4265.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFilter-Based%20Algorithm%20for%20Metering%20Applications%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AFE%20Sigma-Delta%20Channel%20Mapping%20and%20Multi-Phase%20Input%20Support%20on%20TWR-KM35Z75M%20(Metering%20Library)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20currently%20integrating%20the%20Analog%20Front-End%20(AFE)%20configuration%20with%20the%20Metering%20Library%20in%20my%20project%20and%20would%20greatly%20appreciate%20it%20if%20you%20could%20provide%20a%20reference%20example.%3C%2FP%3E%3CP%3EI%20have%20already%20referred%20to%20the%20provided%20example%20file%2C%20%3CSTRONG%3Emeteringlib3Ph_test.c%3C%2FSTRONG%3E%2C%20which%20clearly%20shows%20%3CSTRONG%3Ehow%20to%20use%20the%20Metering%20Library%20APIs%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3EHowever%2C%20We%20would%20greatly%20appreciate%20it%2C%20If%20you%20could%20provide%20a%20more%20complete%20reference%20example%20that%20explicitly%20demonstrates%20the%20integration%20of%20%3CSTRONG%3Eboth%3C%2FSTRONG%3E%20the%20%3CSTRONG%3EAFE%20configuration%3C%2FSTRONG%3E%20and%20the%20%3CSTRONG%3EMetering%20Library%3C%2FSTRONG%3E%20together.%3C%2FP%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EInitialization%20Sequence%3A%3C%2FSTRONG%3E%20The%20correct%20order%20and%20method%20for%20initializing%20both%20the%20AFE%20and%20the%20Metering%20Library.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EData%20Flow%3A%3C%2FSTRONG%3E%20How%20the%20raw%20AFE%20data%20is%20captured%2C%20formatted%2C%20and%20correctly%20passed%20as%20input%20to%20the%20Metering%20Library%20functions.%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EThank%20you%20for%20your%20consideration%20of%20this%20request.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20AFE%20Sigma-Delta%20Channel%20Mapping%20and%20Multi-Phase%20Input%20Support%20on%20TWR-KM35Z75M%20(Metering%20Library)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EI%E2%80%99m%20circling%20back%20to%20see%20if%20you%E2%80%99ve%20had%20a%20chance%20to%20look%20into%20my%20request%20yet.%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
