FREEDOM-K66F
FREEDOM-K66F
a8Chcx
I am using FREEDOM-K66F board, and I want to enable 24-bit system timer at 1ms interrupt.
There is anyone who can provide me the sample code to do so?
Christie
luis_maravilla
Hello Christie,
Could you help us confirm if you are referring to System Tick Timer [SysTick_DelayTicks] or are you referring to another system timer?
Is there a specific example do you want to test? I would recommend checking on the SDK for FRDM-K66F, if an example could apply for your necessities
Best Regards, Luis
