Hi yash bhatt,
If the 50Mhz configuration is 40Mhz in real, and 25Mhz is 24Mhz, it has issues.
You need to check your clock source, and the related configuration, whether it is correct.
Please check the clock configuration, make sure the related setting is OK.
You can check from your original clock source, then check each register configuration, and calculate it.
After the clock works OK, then check more details about your wifi related code.
Any updated information, please kindly let me know.
Kerry
