System Watchdog for K70 using MQX
sudhanshumehta
I have K70 microcontroller.
using MQX4.2
need to use system watchdog (not software watchdog).
do you have any example for that?
sudhanshumehta
sudhanshumehta
kackle123
Except this is an MQX software watchdog, not an MCU/hardware one.
danielchen
Hi Sudhanshu:
Please find the attached validation code for the watchdog module.
In the MQX installation folder, there is a software watchdog demo.
Freescale_MQX_4_2\mqx\examples\watchdog
sudhanshumehta
I want system reset watchdog example.
i feel in example section, there is task reset example.
please correct me if i am wrong.
sudhanshumehta
This will work on K70 with MQX? Have you tested?
