2x5 idc .05" cable kwikstik
已解决
跳至解决方案
2,086 次查看
mjg8t
Hi there,
I have been working with the kwikstik and have now designed my first PCB with a k20 part onboard.  I would like to program the board uisng the j-link on the kwikstik and am looking for the easiest option to do so.  It would be optimal to use an existing 2x5 .05" pitch IDC cable and poplulate the 2x5 SWD header on the quickstik.  However I am  not finding any sources for prebuilt cables with the 2x5 female connector on both ends.
Does anyone know of any resources to find such?  Or have other direct solutions?
Thanks.
1 解答
1,816 次查看
mjg8t
3 回复数
1,816 次查看
mjg8t
FYI.  For those who might also be searching:  The closest I have been able to find are these connectors on ebay.
http://www.ebay.com/itm/300720309884?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_2851wt_75...
1,816 次查看
mjg8t
1,817 次查看
mjg8t
Best yet:
http://www.digikey.com/scripts/DkSearch/dksus.dll?wt.z_header=search_go&lang=en&keywords=FFSD-05-D&x...
Or it looks like you can get samples directly from samtec.
