procesador experts & ksdk
1,378件の閲覧回数
alfredobuena
Quie may explain why there instruccinoes that work when I open a new project with expert processor without sdk and do not work when the same project I open it with expert processor and sdk both branded , a sign motioning appears that the component or the board does not support it I'm working with KL46z Palca 256 ... I hope I was clear in my question ... Alfred
1,277件の閲覧回数
ZhangJennie
there are two types of processor expert component: sdk pe components and  pe component. these two types of pe components can not be used in same project.  that's to say the pe component can not work normally in a ksdk project.
when you create a new pe project with KDSK option select, we will use the first type pe components;  if not select it, use second type one.
in Components libary, we will see what components are available for the current project
does this answer your questions?
Jennie Zhang
1,277件の閲覧回数
ZhangJennie
HI,
I am not quite understand your question.
can you please explain:
1.  what's your KDS version?
2.  can you please show your problem with screenshots?
thanks!
Jennie Zhang
