problems encountered when I 'make' a file
1,419 次查看
raybreslau
I had been 'making' the file very consistently but I modified the main.c file and tried to compile. I keep getting the same error message:
C:/Users/CTSI-RBRESLAU/workspace.kds/test5/Generated_Code/Byte1.h:113:27: error: called object is not a function or function pointer
#define Byte1_PutVal(Val) (BitsIoLdd1_PutVal(BitsIoLdd1_DeviceData, ((Val))))
../Sources/main.c:153:3: note: in expansion of macro 'Byte1_PutVal'
   Byte1_PutVal(0xFF);
1,335 次查看
ZhangJennie
Hi Ray,
I suggest you post your project here, thus our engineer can check your problem easier. thanks!
Jennie Zhang
1,335 次查看
Hello Ray,
Could you please provide more information about your project and problem.
For example ,  what project ? which chip ?  Does your project is a demo one or create by your
self ? With   KSDK? ....?
Alice
