pegdbserver_console.exe has failed?
bradleyroper
I am using kinetics design studio with a FRDM-K20D50M board, and every time I launch the debugger it comes up that the pegdbserver_console.exe has sopped working, and I cant debug the program to the board. Any help?
Thank-you
alikader
Hi, I was having the same issue, so i just reinstalled the PEDrivers and everything started working again. You can try reinstalling the drivers from KDS_v3\pemicro folder. Good luck
Ali
DavidS
Hi Bradley,
When in the debugger perspective, please make sure all breakpoints are deleted, then re-try debugging.
David
