.map file generation problems
1,883 次查看
cavebiker
Hello KDS people,
I started an example project using KDS and MQX 4.2, I started with the gpio example for the twrk60f120m platform.
I was generating a .map file but after I started playing with the linker file (intflash.ld) this .map file went away.
I have the Print link map box checked in:
Any ideas are appreciated.
Cheers,
Tom
1,649 次查看
cavebiker
I got it.
I un-checked the (Print link map) box
Cheers!
1,650 次查看
cavebiker
I got it.
Cheers!
