j-link GDB Server failed
2,479 次查看
dharmeshkanzari
i am using FRDM k82f board. And my ide is KDS 3.2. But whaen i am trying to load some code in my board i face error "j-link GDB Sereve failed". Please see attached file.
Onr more thing i am using "opensda v2.1.bin" file in my board for jlink drivers.
Please help me to solve this problem
Thanx,
Dharmesh
Original Attachment has been moved to: OpenSDA_V2_1-(1).bin.zip
2,061 次查看
harshpatel
Hello Dharmesh
This error may occurs due to improper j link to Controller connection. Make sure that jlink pins 1,3,2,4 and 10 is connected to relevant controller SWD pins. Jlink pin outs are as follows:
Let me know if any....
Thanks & regards
Harsh
2,061 次查看
Hello Harsh,
If you  use the demo board frdm-k82 , and the jink debugger ,
please first make the connect is right , then check the configuration of KDS debug view .
Hope it helps
Alice
2,061 次查看
Hello Dharmesh,
Please show the debugger configuration view on your side .
And also you'd better show the steps one by one how do you download project .
What about your PC system ?
I used Windows , it can work well .
Alice
