frdmk64f KDS disassembly
2,071 次查看
axelacosta
I am wondering how to enable the disassembly view while debugging code running on a FRDM-K64F.
I am new to the whole KDS environment, but I followed all the instructions for project generation provided by the "get started" tutorial.
I am using KDS 3.0 and KSDK 1.2 and the board has the mbed openSDA2.0.
标记 (1)
1,792 次查看
BlackNight
Use menu Window > Show View > Disassembly:
which gives you
I hope this helps,
Erich
1,792 次查看
axelacosta
Hi Erich,
Well the disassembly window was there but it was empty.
Apparently closing the window and reopening it seemed to work.
Is this a known bug?
1,792 次查看
BlackNight
Hi Axel,
yes, this is a known problem.
Erich
