What is my code size?
2,691件の閲覧回数
neilporven
Senior Contributor I
Hi everyone,
Does anyone know if Kinetis SDK 3.0 has a log file, GUI, console configuration that tell you what your
code size is?  How much is actually going to the processor?  If it doesn't have a feature that displays
this information, then how can I go about at least estimating how much code, between the SDK and
what I have written?
Neil
2,524件の閲覧回数
Hello Neil,
Please enable the "Print size" :
then build your project , you can see the code size on the "Console " window :
Hope it helps
Alice
3 返答(返信)
2,525件の閲覧回数
Hello Neil,
Hope it helps
Alice
2,524件の閲覧回数
BlackNight
Hi Neil,
in addition to what Alice has provided:
  1. This article explains the information produced by 'size' utility: text, data and bss: Code and Data Size Explained | MCU on Eclipse
  2. To know the code/data size for each file: Listing Code and Data Size for each Source File with GNU and Eclipse | MCU on Eclipse
I hope this helps,
Erich
2,524件の閲覧回数
neilporven
Thank you Alice!
