Watchpoints Not Working--how do I fix?
5,672件の閲覧回数
andrewmeyerbti
KDS version 3.2.0
USBDM 4.12.1.230
Chip S9KEAZ128AMLH
Setup seems to work fairly well, but I have come upon a situation where I really could use a watch point.  According to the chip documentation there are two.
I can follow Eric Styger's instructions https://mcuoneclipse.com/2018/08/11/tutorial-catching-rogue-memory-accesses-with-eclipse-and-gdb-wat... and everything appears normal; except that it never stops the execution, even when passing a known variable access.  Everything appear as advertised in Eric's blog--it just doesn't work.
Does anyone have any hints on how to go about diagnosing/fixing this problem with eclipse (or USBDM?)
Can anyone tell me how to manually install a watchpoint, or how to debug an unknown random change to a variable without a watchpoint?
Thanks Very much for your assistance!!
2 返答(返信)
5,655件の閲覧回数
andrewmeyerbti
Thanks Eric!
Peter O'Donoghue, any comments?  Your USBDM software has been a great help by the way.  I am using a modified FRDM KEAZ64Q64 demonstration board as the interface hardware to my custom board.  I believe that means USBDM is running on a MK20DX128VFM5 chip to program an S9KEAZ128AMLH on my custom board.  Everything seems to work very reliably since i learned to turn on the 5V supply in the server app, except for this lack of watchpoint functionality.
5,664件の閲覧回数
ErichStyger
Specialist I
Hi @andrewmeyerbti ,
I don't have USBDM and the device you are using, so cannot really comment, except that it works as described with LinkServer, P&E and Segger.
I would recommend that you try to remove/delete all other breakpoints: just having a single watchpoint active, because you might run over the available hardware breakpoints and you won't get an error message about this. The other thought I have is that USBDM might not support watchpoints: have you tried already with a J-Link or P&E maybe?
I hope this helps,
Erich
