Hi Oliveira,
I see the error in your project as well....sort of.
The console tab indicates that it is a warning and the problems tab indicates it is an error.
Since the application elf file is generated and I can download and run the application I believe that the problem tab is lying to us (actually guessing this is a KDS issue).
I will submit this to the KDS team to investigate.
David
