TimerInt_LDD component
1,728 次查看
shauldorf
Contributor V
I want to implement variable period Internal Interrupt.
I’m using FRDM-K64F and KDS3.0 + KSDK1.2
Is there any solution how to change dynamically  (during runtime)  Period/Frequency of TimerInt_LDD component.
I have seen that the relevant Kinetis methods in TimerInt_LDD are not implemented.
Shaul
1,506 次查看
ZhangJennie
Hi shaul.
TimerInt_LDD can not change frequency during runtime. I suggest you use PPG component instead, which can change output radio and frequency dynamically.
please refer this link:
Re: How to change PWM frequency
can this help you?
Jennie Zhang
1,507 次查看
ZhangJennie
Hi shaul.
can this help you?
Jennie Zhang
