Should KDS update server be changed
JonathanHess
One of the steps in "Getting Started with Kinetis SDK (KSKD) v.2.1.pdf" was to "check for updates."  Doing so results in a "No updates found" dialog on top of a dialog with:
No repository found at http://gnuarmeclipse.sourceforge.net/updates.
That probably explains why no updates were found.  What url in KDS should be updated and to what?
BlackNight
Hi Jonathan,
GNU ARM Eclipse has been migrated to GitHub (Welcome to GNU ARM Eclipse! ), but the Eclipse update site is still at http://gnuarmeclipse.sourceforge.net/updates
However, some SourceForge areas seemed to have in the past months problems (denial of service or other threads) and was now accessible (which seems to be the case right now). So I suggest that you give it a try later.
I hope this helps,
Erich
PS: other installation guide/page: How to install the GNU ARM Eclipse plug-ins?
JonathanHess
After your reply I checked from my Eclipse/mars install and... it is correctly using http://gnuarmeclipse.sourceforge.net/updates.  No idea why KSD 3.2 isn't working with it unless it could be an indendent or older jre.
This makes me want to head back over to mcuoneclipse and read up on how to install the nxp/freescale plugins directly in eclipse/mars but...  I'd have to think if that will actually buy me anything with the targets I have and mbed.  It would definitely complicate the "mbed<-cli> export -i <something eclipse based>" is broken test.
BlackNight
Hi Jonathan,
I think it is really a prolem with SourceForge. I tried it again and it works now:
Erich
