Program "make" not found in PATH...
ソリューションへジャンプ
7,246件の閲覧回数
jacquesnapoleon
I installed Kinetis Design Studio and download Kinetis KE02-SC.zip examples.
After importing the projects in IDE, all projects appear with problems and the error "Program "make" not found in PATH".
Could you please help...
Thanks and regards.
4,814件の閲覧回数
Hello Jacques,
Does your KE02-SC example support KDS ?
In my hand ,it only support CW ,IAR and KEIL .
Hope it helps
Alice
6 返答(返信)
4,814件の閲覧回数
TICS_Fiona
Hi Jacques
The demo examples KE02-SC.zip are based on CodeWarrior, IAR and Keil. You may open or import the example project with any above IDE.
CodeWarrior v10.6.4 can be downloaded from:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-MCU10
Or if you would import the project into KDS, please refer to this doc under your KDS folder:
C:\Freescale\KDS_3.0.0\doc\KDS_Porting_Guide.pdf
Fiona Kuang
Technical Information & Commercial Support
4,814件の閲覧回数
jacquesnapoleon
Hi Fiona,
Thanks to confirm what was mentioned earlier by other people above...
Anyway, as a suggestion this could help to enhance getting started manual by including starting from scratch procedures with KDS and available examples for this IDE if any...
Thanks and regards,
Jacques.
4,814件の閲覧回数
jacquesnapoleon
Hello Alice,
Thanks for you reply.
Actually KE02-SC examples do not support KDS but these are the only available examples that can be found at KDS download web page...
Thanks again.
Jacques.
4,814件の閲覧回数
BlackNight
Hi Jacques,
There is a CodeWarrior project converter in KDS:
It might not be able to convert anything, but should help you getting the project to KDS.
I hope this helps,
Erich
4,814件の閲覧回数
jacquesnapoleon
Hi Erich,
Thanks for your support.
I will try to convert my project file following your instructions and will let you know.
Jacques.
4,815件の閲覧回数
Hello Jacques,
Hope it helps
Alice
