debug twr-k60 by KDS 3.0.0 on Linux
helderhdw
Hi All,
I'm using KDS in Linux, and I would like to use the OSJTAG (usb debug in my twrk60n512). I made a debug configuration with -> "GDB PEMicro Interface Debugging", but the following problem occurs:
Error in services launch sequence
Timed out trying to launch GDB Server.
Att,
Francisco Helder
Hello Helder,
Have you install the drivers of the OSJTAG ? It can download here P&E Microcomputer Systems  .
You can fund it from the User's Manual :
And then , please check here :
Hope it helps
Alice
helderhdw
Hi Alice,
thanks a lot about support. The problem was old software in OSBDM, and the tools to update only by windows. I plugged the board in the computer with windows and updated firmware.  thanks a lot again...
best regards,
Francisco Helder
Hi Helder,
Welcome !
Alice
