PWM duration measurement usingcomponent LDD_TimerUnit
1,600件の閲覧回数
artembilik
Dear colleagues. I ask you to share the experience. In this area. I'm interested in. How to measure the length of a micro seconds or beats. How anyone. Using the function component LDDTimerUnit in capture mode. I want for example to eight channels receiver Futaba get duration, make the necessary calculations, and give to the servo aircraft. Ie who understands me make stabilization flight manual.
Thank you, gentlemen.
1,462件の閲覧回数
ZhangJennie
Hi Artem.
You can use the TimerUnit_LDD and configure some of its channels for capture mode.
Please see below picture for example. You can find more information in the help of the TimerUnit_LDD component.
Hope this helps!
Zhang Jun
this answer is for you, if it helps, please click on "Correct Answer" button, thanks!
1,463件の閲覧回数
ZhangJennie
Hi Artem.
Hope this helps!
Zhang Jun
