PE Micro debugging issues with KDS and MKL03 microcontroller
2,023 次查看
arturzak
We have been using KDS with PEMicro to debug MKL03 micro.  The debug session starts and breaks at main() as expected, but when we resume running, there are breakpoints encountered at different RAM locations (0x20000258, etc.) where code should not even be running.  Has anyone experienced similar issues, and is there a way to prevent these breakpoints from occurring?
1,656 次查看
arturzak
Alice,
Creating simple projects nor using demo applications did not help the issue.
I uninstalled the PEMicro Eclipse Plug-in from KDS, and re-installed (from Install New Software menu) and that seemed to have cleared my issues.  After the fresh install of the plugin, the debugger operates as expected.
Thank you for your prompt reply.
1,656 次查看
Hello Artur,
- Please create one simple project to have a try , tell me the result .
- What about your board, demo board or customer board ?
- You can take screenshot show us the error , or you can send your project to me .
Alice
1,657 次查看
arturzak
Alice,
1,656 次查看
Hello Artur,
Ok , thank for you show the method .
Alice
