Kinetis Design Studio V1.1.1 Processor Expert bug?
3,377件の閲覧回数
adrianomitre
When I start KDS the following is presented on Console and stdout:
com.freescale.processorexpert.core: System directory = /opt/Freescale/KDS_1.1.1/eclipse/ProcessorExpert
com.freescale.processorexpert.core: User working directory = /home/username/Processor Expert/PEXDRV_PE5_3
com.freescale.processorexpert.core: Internal cache directory = /home/username/Processor Expert/PECache/12c6317b
com.freescale.processorexpert.core: Plugin  Plug-in "com.freescale.processorexpert.core.service" was unable to instantiate class "com.processorexpert.core.client.PEApplicationClient".
Meanwhile, stderr reads:
org.eclipse.core.runtime.CoreException: Plug-in "com.freescale.processorexpert.core.service" was unable to instantiate class "com.processorexpert.core.client.PEApplicationClient".
  at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
  at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
  at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
  at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
  at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
  at com.processorexpert.core.PECoreActivator.start(PECoreActivator.java:119)
  at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
  at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
  at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
  at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
  at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:478)
  at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
  at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:109)
  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
  at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
  at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
  at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
  at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
  at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
  at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
  at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
  at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
  at java.lang.ClassLoader.defineClass1(Native Method)
  at java.lang.ClassLoader.defineClass(ClassLoader.java:760)
  at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClassHoldingLock(ClasspathManager.java:638)
  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:613)
  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:574)
  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:492)
  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:465)
  at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
  at com.processorexpert.core.compiler.AHWT.initializeModule(AHWT.java:228)
  at com.processorexpert.core.application.PE_API_PEApplication.globalInitialization(PE_API_PEApplication.java:479)
  at com.freescale.processorexpert.cde.ui.model.Container.<init>(Container.java:1000)
  at com.freescale.processorexpert.cde.ui.model.Container.getDefault(Container.java:222)
  at com.freescale.processorexpert.cde.ui.providers.CDEContentProvider.<init>(CDEContentProvider.java:60)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
  at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
  at java.lang.reflect.Constructor.newInstance(Constructor.java:408)
  at java.lang.Class.newInstance(Class.java:433)
  at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
  at org.eclipse.ui.internal.navigator.extensions.NavigatorContentDescriptor.createContentProvider(NavigatorContentDescriptor.java:377)
  at org.eclipse.ui.internal.navigator.extensions.NavigatorContentExtension$1.run(NavigatorContentExtension.java:129)
  at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
  at org.eclipse.ui.internal.navigator.extensions.NavigatorContentExtension.internalGetContentProvider(NavigatorContentExtension.java:125)
  at org.eclipse.ui.internal.navigator.NavigatorContentService.extractContentProviders(NavigatorContentService.java:1214)
  at org.eclipse.ui.internal.navigator.NavigatorContentService.updateService(NavigatorContentService.java:391)
  at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.inputChanged(NavigatorContentServiceContentProvider.java:109)
  at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:276)
  at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1690)
  at org.eclipse.ui.navigator.CommonNavigator.createPartControl(CommonNavigator.java:212)
  at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:142)
  at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:174)
  at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:323)
  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  at java.lang.reflect.Method.invoke(Method.java:483)
  at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
  at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
  at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
  at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
  at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
  at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
  at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
  at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
  at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
  at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
  at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:526)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:511)
  at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:61)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
  at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1147)
  at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:96)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
  at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:62)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
  at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
  at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
  at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
  at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:581)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1042)
  at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
  at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
  at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
  at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
  at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
  at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
  at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
  at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
  at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
  at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
  at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
  at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
  at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
  at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
  at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Caused by: java.lang.ClassCircularityError: com/processorexpert/core/pe/TPackageFilter
  at com.processorexpert.core.pe.Config.initializeModule(Config.java:5198)
  at com.processorexpert.core.shared.Utils_Console.initializeModule(Utils_Console.java:125)
  at com.processorexpert.core.shared.Utils_StrList.initializeModule(Utils_StrList.java:1876)
  at com.processorexpert.core.shared.Utils_Text.initializeModule(Utils_Text.java:2123)
  at com.processorexpert.core.pe.Utils.initializeModule(Utils.java:889)
  at com.processorexpert.core.components.Beans.initializeModule(Beans.java:182)
  at com.processorexpert.core.application.PE_API_PEApplication.globalInitialization(PE_API_PEApplication.java:480)
  at com.processorexpert.core.application.PE_API_PEApplication.doInitApplication(PE_API_PEApplication.java:223)
  at com.processorexpert.core.client.PEApplicationClient.<init>(PEApplicationClient.java:104)
  ... 167 more
When I exit KDS, just after entering it, I have the following pop-up displayed:
And the following is print to stdout
[CDE]PEx Service Did not start correctly
And the following to stderr
Job found still running after platform shutdown.  Jobs should be canceled by the plugin that scheduled them during shutdown: com.processorexpert.core.internal.PMOpenProjectFromHistory$1
When I create a new workspace, the problem goes away, but it reappears after reacreating the project. I do not feel like sharing the whole workspace and project, but I may attach specific configuration files as requested. I am running Ubuntu 14.04 LTS 64-bit with both 32-bit and 64-bit JDKs. By the way, why there is no 64-bit KDS package available?
2,887件の閲覧回数
liborukropec
Hi Adriano,
thank you for you feedback. We have reproduced the issue on 64bit Linux too, it happens only in some circumstances. We will address this bug in the next KDS update. As a workaround either use 32 bit Linux (probably not preferred) or go to the installation directory, go to the eclipse/plugins/  and delete/move/rename the CDE plugin com.freescale.processorexpert.cde.ui_1.7.0.RT6_2_b1428-0612.jar that is causing this problem. You will loose the CDE functionality, but probably now you do not need to create your own components and Processor Expert will start working.
Libor
4 返答(返信)
2,887件の閲覧回数
adrianomitre
UPDATE: I could nail down the issue to Processor Expert perspective and found somewhat of a workaround: closing the Processor Expert perspective before exiting KDS.
The minimal steps to reproduce the bug are the following:
  1. Start KDS from the command-line, by running the script below.
  2. In the Workspace Launcher window, choose a non-existing folder as the workspace (e.g., "~/kds_pex_bug_workspace"), in order to have a clean, untainted workspace.
  3. When the IDE loads, open the Processor Expert perspective: Window->Open Perspective->Other->Processor Expert.
  4. Quit KDS: File->Exit. (It will exit gracefully, without any errors.)
  5. Start KDS again and choose the just created workspace (e.g., "~/kds_pex_bug_workspace").
  6. Meet the errors described in the original post. (I attached stdout.txt and stderr.txt; to see the window alert, you may have to wait a little while before exiting.)
Workaround: Closing the Processor Expert perspective before quitting KDS, then restart it.
KDS start script:
#!/bin/bash
export JAVA_HOME=/usr/local/java/i386/current_jdk
export PATH="/usr/local/java/i386/current_jdk/bin:$PATH"
/opt/Freescale/KDS_1.1.1/eclipse/eclipse &
Java 32-bit environment:
$ /usr/local/java/i386/current_jdk/bin/java -version:
java version "1.8.0_20"
Java(TM) SE Runtime Environment (build 1.8.0_20-b26)
Java HotSpot(TM) Server VM (build 25.20-b23, mixed mode)
2,887件の閲覧回数
BlackNight
Hmm, strange, maybe it is because of the 64bit environment and version. I pass it to the Processor Expert team so they could have a look.
About the 64bit package question: I see you posted a question already here Why there is no 64-bit DEB package for Kinetis Design Studio?.
Erich
2,887件の閲覧回数
adrianomitre
Additional info relevant to the Processor Expert team: the above refers to KDS 1.1.1 with Processor Expert for KDS 1.1 – Update 1.
2,888件の閲覧回数
liborukropec
Hi Adriano,
Libor
