KDS synthiax error but not true
2,364 次查看
pietrodicastri
Senior Contributor II
Good morning
I have a behaviour with KDS.
The editor is outlining as error an expression, but build time no error is present.
This begun to happen since some time, after the same project has correctly worked for months.
Suggestions???
Thank You
标记 (1)
2,259 次查看
BlackNight
Hi Pietro,
maybe I don't see it, but I don't see an error in your screen shot?
As a piece of information: Eclipse is using the 'Indexer' for its internal parsing. So it could be that your Indexer database somehow is not correct. See Fixing the Eclipse Index | MCU on Eclipse .
I hope this helps,
Erich
2,260 次查看
BlackNight
Hi Pietro,
I hope this helps,
Erich
2,258 次查看
pietrodicastri
Yes ,,
Rebuild the index was sufficient,,,
Thank You
2,259 次查看
trytohelp
Hi Pietro,
Can you please provide us a short example reproducing the problem ?
What is the KDS tool version used ?
Pascal
NXP Technical Support
