I modified existing KSDK libraries for MK22F512 MCU to make them work for MK22F256 MCU. I changed all the project settings, linker files, changed CPU etc. The project compiles fine and it also seems to link correct files from MK22F256 because if I try to call any function from MK22F512, I get an error or a message saying that the function is implicitly declared. This makes me think that its compiling and linking the correct files but when I right click on a function and select "Open Declaration", I see that it takes me to the files from MK22F512 folder. I tried deleting the files in MK22F512 folder and I still see that KDS takes me to an empty file named after MK22F512.
Please advice me on what I am doing wrong?
Priya
已解决! 转到解答。
Hi Priya,
if Eclipse takes you to the wrong location, then probably your Index (that's how Eclipse stores the information) is somehow wrong. I recommend that you rebuild the index to see if this fixes the problem, see Fixing the Eclipse Index | MCU on Eclipse
I hope this helps,
Erich
Hello Priya,
Sorry i'm confuse about what the steps you done . And there is the MK22FN256 sdk lib , why do you porting it use
the MK22FN512 lib ? Or do you meaning porting one application project about MK22FN512 to the chip of MK22FN256 ?
Could you please tell me how to reproduce your problem step by step , or tell me what is your aim, then i will check how
to help you .
Alice
Hi Priya,
I hope this helps,
Erich
