K70 bareMetal code warrior Project Clean problem in Kinetis Design Studio
2,973 次查看
tholkapiyanv
 K70 bareMetal Project convert to KDS and Compile without error first time
but next time compile error.
and clean the project error :  make (e=87): The parameter is incorrect.
Kindly anyone give the solution
   V.Tholkapiyan
5 回复数
2,745 次查看
Hello Tholkapiyan V,
What about the version of KDS ?
You'd better share your project then we can check it .
Alice
2,745 次查看
tholkapiyanv
Hello Alice Yang
       My Kinetis Design Studio
       Version: 3.2.0
Code compile with no error without modified code.
with modified the code error the last add project file name or folder name.
V.Tholkapiyan
2,745 次查看
Hi V.Tholkapiyan,
So now your problme solved after fix project file name and folder name ?
If no, please how and what name you modify.
Alice
2,745 次查看
tholkapiyanv
Hello Alice Yang,
   Hi i have attached Screen Shot
      V.THOLKAPIYAN
2,745 次查看
Hi   V.THOLKAPIYAN,
The screenshot didn't show code in  usbmsgq.c:38:16 as error reminder.
If the problme still can't sloved , I recommend you uploading your project.
Also you submit  a  service request on NXP Support  How to submit a new question for NXP Support ,
then attach your project , If project can not public shared on community.
Alice
