How do I Add Undo/Redo buttons to KDS toolbar?
brianheisler
With...
Kinetis Design Studio 3.1.0
I want to add undo and redo buttons to the KDS toolbar.
One would think that this would be a simple task.
Nonetheless...
(In Window --> Customize Perspective --> Tool Bar Visibility), the entire edit menu (and it's sub-items) is missing.
I have found no other method for adding these functions to the toolbar.
Is there a workaround for this?
Thanks for your help.
BlackNight
Hi Brian,
ah, I see now what you mean :-)
This one should help you with what you want: How to Add Undo/Redo Toolbar Buttons to Eclipse | MCU on Eclipse
I hope this helps,
Erich
BlackNight
Hi Brian,
I have it visible:
Maybe you could try to reset the perspective?
I hope this helps,
Erich
brianheisler
Erich-
The problem is that these items are not shown under the Tool Bar Visibility tab which, as I understand it, is required to establish their appearance on the toolbar.
(Your post shows the Menu Visibility tab. Mine looks just like yours under this tab.)
Have you found a method for putting these items on your toolbar?
Thanks.
-Brian
BlackNight
Hi Brian,
I hope this helps,
Erich
brianheisler
Erich-
I had to do some digging before I located the dropins folder but that did the trick!
Thank you for your help!
-Brian
