Group S19 image
Group S19 image
2,174 次查看
arnogir
Senior Contributor II
Hello
In many application I have based on Kinetis, In production phase, I have to flash with the P&E the USB bootloader and then with the boot, insert the USB key containing the programme S19 image which will flash it and jump to it.
So I have two programme in the flash (Boot + Application)
Are they a way to create a unique flash image containing both program? In other word, can we merge 2 s19 (or Abs) file in only one?
By this way, in production phase, the second step which consist to flash the application with USB bootloader will be not necessary.
thank you
2,023 次查看
ZhangJennie
please refer Erich's article as below
https://mcuoneclipse.com/2016/02/26/merging-s19-files/
can this help you?
Jennie Zhang
2,023 次查看
arnogir
Light, fast, efficient, my personal research had not given anything!
Thank for your help, I think the link is what I research.
:smileyhappy:
2,023 次查看
ZhangJennie
You are welcome!
Jennie Zhang
2,024 次查看
ZhangJennie
can this help you?
Jennie Zhang
