Generate makefile for linux with KDS for KW40/41
1,548 次查看
sensenthuran
How to generate a makefile for Linux build machine from KDS for KW40/41 application (say hci_app)?
1,281 次查看
ZhangJennie
In addition, Makefile is automatically generated after a successful build under the same folder with .elf file.
user can edition makefile style and syntax in KDS preferences window.pastedImage_0.png
Hope this helps!
Jennie Zhang
1,281 次查看
MarekTrmac
just select Build command in the menu. Makefile is created automatically in Debug folder.
Marek
