Hi:
I'm using KDS and uTasker O.S with FRDM-K64F... I set a fixed IP to the board and used it as a webserver with no problem... But if i change that IP, compile and flash again wid KDS and J-Link, the old IP remains... the same happens with the html files i loaded to it...
Using uVision, is possible to workarround this problem by erasing the device with the erase button of that IDE, but i cannot find a simple way to do it with KDS 3.0
Is there any function similar to uVision's erase?
Solved! Go to Solution.
Hi:
I've finally solved this... I just created a project for the board that fills the text region of memory with 0xff... i found something similar in a forum and it worked
Hi:
