Disable triple click
1,795 次查看
Onemars
Is there a way to disable the triple click in the KDS editor? (KDS 3.2)
It is used to select the whole line, but it also has this bad behavior:
- double click a word in a line
- within a second, click a word in the line below
This causes the whole line below to be selected.
Thank you.
1,618 次查看
Hello Gabriele ,
Sorry it seems there isn't  the function to disable triple click .
Hope it helps
Alice
1,618 次查看
Onemars
Thanks for your time Alice.
Clearly, it is a problem of Eclipse (or Eclipse CDT?) not KDS. I've tried to install the latest Eclipse Oxygen (platform 4.7.0 and CDT 9.1.0) and it has the exactly same behavior, so I think it is a strange but wanted feature.
