Debug Variables
Debug Variables
1,902 次查看
dporada
I am debugging a new project that uses an MKE02Z32VLC4.  I don't see anything in the variables window, and I am unable to add Global Variables.  The only menu selections that are available are "Select All" and "Copy Variables".
Am I missing a plugin?
1,793 次查看
BlackNight
Hi Don,
starting with Eclipse Kepler, the variables view only shows local/stack variables. You need to use the Expressions view, see Variable Debugging with Eclipse Kepler | MCU on Eclipse
I hope this helps,
Erich
1,793 次查看
BlackNight
Hi Don,
I hope this helps,
Erich
