Can't read the output file size, and don't create S19 file
3,774 次查看
arnogir
Senior Contributor II
s
Hello
I read the following document:
http://mcuoneclipse.com/2014/05/04/printing-code-size-information-in-eclipse/
Binary (and S19) Files for the mbed Bootloader with Eclipse and GNU ARM Eclipse Plugins | MCU on Ecl...
I follow the asked step, but nothing appear in the console.
Also, S19 is file not create
Bellow is my console. Please, could you tell me some check to do to work correctly?
17:29:27 **** Rebuild of configuration Debug for project cplus_sqm4 ****
Info
: Internal Builder is used for build
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\ANA\CT_ADS1248_Cfg.o ..\..\Sources\ANA\CT_ADS1248_Cfg.c
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\rootwindow.o ..\..\Sources\LCD\rootwindow.cpp
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\RTC\SGC400_DV_Timer.o ..\..\Sources\RTC\SGC400_DV_Timer.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\ANA\DV_DAC.o ..\..\Sources\ANA\DV_DAC.c
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\pegapp.o ..\..\Sources\LCD\pegapp.cpp
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\ScreenStat.o ..\..\Sources\LCD\ScreenStat.cpp
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\ScreenModifParam.o ..\..\Sources\LCD\ScreenModifParam.cpp
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\ANA\DV_AD7949.o ..\..\Sources\ANA\DV_AD7949.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\SM\SnowMaker.o ..\..\Sources\SM\SnowMaker.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\ANA\AP_ANA.o ..\..\Sources\ANA\AP_ANA.c
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\ScreenParameter.o ..\..\Sources\LCD\ScreenParameter.cpp
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\ANA\IF_ANA.o ..\..\Sources\ANA\IF_ANA.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\USB\usb_file.o ..\..\Sources\USB\usb_file.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\SM\AP_Default.o ..\..\Sources\SM\AP_Default.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\Communication\Serial\SerialModbus\SGC400_SerialModbus.o ..\..\Sources\Communication\Serial\SerialModbus\SGC400_SerialModbus.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\Other\SGC400_Init.o ..\..\Sources\Other\SGC400_Init.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\GPIO\DV_PORT.o ..\..\Sources\GPIO\DV_PORT.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\GPIO\CT_KEYBOARD.o ..\..\Sources\GPIO\CT_KEYBOARD.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\Communication\DV_SERIAL.o ..\..\Sources\Communication\DV_SERIAL.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\SM\SMDefaut.o ..\..\Sources\SM\SMDefaut.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\GPIO\DV_BUS.o ..\..\Sources\GPIO\DV_BUS.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\SM\SMCycle.o ..\..\Sources\SM\SMCycle.c
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\ScreenExploitation.o ..\..\Sources\LCD\ScreenExploitation.cpp
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\ScreenHourSetup.o ..\..\Sources\LCD\ScreenHourSetup.cpp
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\ANA\CT_AD7949.o ..\..\Sources\ANA\CT_AD7949.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\SM\SMParam.o ..\..\Sources\SM\SMParam.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\SM\AP_Param.o ..\..\Sources\SM\AP_Param.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\Main\ffs.o ..\..\Sources\Main\ffs.c
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\ScreenIOAna.o ..\..\Sources\LCD\ScreenIOAna.cpp
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\SM\SMTimer.o ..\..\Sources\SM\SMTimer.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\Eth\DV_ETH.o ..\..\Sources\Eth\DV_ETH.c
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\ScreenCalib.o ..\..\Sources\LCD\ScreenCalib.cpp
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\ANA\CT_ADS1248.o ..\..\Sources\ANA\CT_ADS1248.c
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\ScreenIODig.o ..\..\Sources\LCD\ScreenIODig.cpp
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\SM\SMManuel.o ..\..\Sources\SM\SMManuel.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\SM\SMCalcul.o ..\..\Sources\SM\SMCalcul.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\GPIO\DV_BUS_Cfg.o ..\..\Sources\GPIO\DV_BUS_Cfg.c
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\ScreenAdvancedSetup.o ..\..\Sources\LCD\ScreenAdvancedSetup.cpp
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\Eep\IF_EEP.o ..\..\Sources\Eep\IF_EEP.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\ANA\DV_ADS1248.o ..\..\Sources\ANA\DV_ADS1248.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\ANA\IF_DAC.o ..\..\Sources\ANA\IF_DAC.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\PWM\SGC400_DV_PWM.o ..\..\Sources\PWM\SGC400_DV_PWM.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\RTC\SGC400_DV_RTC.o ..\..\Sources\RTC\SGC400_DV_RTC.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\Eep\AP_MEMORY.o ..\..\Sources\Eep\AP_MEMORY.c
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\Main\main.o ..\..\Sources\Main\main.cpp
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\GPIO\CT_IO.o ..\..\Sources\GPIO\CT_IO.C
arm
-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -D_AEABI_LC_CTYPE=C -D__VFPV4__=1 -D__STRICT_ANSI__=1 -D_DEBUG=1 -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu++11 -fabi-version=0 -fno-exceptions -fno-strict-aliasing -c -o Sources\LCD\ScreenManu.o ..\..\Sources\LCD\ScreenManu.cpp
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\USB\usb_classes.o ..\..\Sources\USB\usb_classes.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\SM\SMGestionSortie.o ..\..\Sources\SM\SMGestionSortie.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\GPIO\DV_PORT_Cfg.o ..\..\Sources\GPIO\DV_PORT_Cfg.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\Main\debug.o ..\..\Sources\Main\debug.c
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\USB\usb_task.o ..\..\Sources\USB\usb_task.c
arm
-none-eabi-objcopy -O srec cplus.elf cplus.srec
arm
-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -DPEG_TARGET_BUILD -DPEG_TASK_ID=5 -DTWR_K70F120 -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Generated_Code -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp/Sources -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/bsp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/psp -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/mfs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/ffs -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/shell -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/usb -IC:\Freescale\Freescale_MQX_4_1/lib/sqm4k70_eb.kds/debug/rtcs -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\USB -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\LCD -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Main -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\GPIO -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Other -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\CAN -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Communication\Serial\SerialModbus -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Flash -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\ANA -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\PWM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\RTC -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eep -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\SM -IC:/Projet/xxx/SGC400_GUN_1/Kds_Project\..\\Sources\Eth -IC:\Freescale\swellsoftware\peglite\peg/include -IC:\Freescale\swellsoftware\peglite\peg/include/screendrv -IC:\Freescale\swellsoftware\peglite\peg/include/rtos -IC:\Freescale\swellsoftware\peglite\peg/include/touchdrv -std=gnu11 -c -o Sources\Eth\DV_ETH_Cfg.o ..\..\Sources\Eth\DV_ETH_Cfg.c
arm
-none-eabi-objcopy: 'cplus.elf': No such file
Info
: Parallel threads used: 4
17:29:44 Build Finished (took 16s.208ms)
3,398 次查看
arnogir
Senior Contributor II
I found the problem.
In fact in my project properties : in "C/C++ Build" / Behavior the case "Enable parallel build" was tick to use the 4 Computer processor.
When I disable this option, the post built command work! And I obtain the size and the S19 file...
Then this is a Bug of KDS???
else it exist a simpliest way to obtain output data size: Same to obtain s19 file in "C/C++ Build" / Setting / ToolChains, set "PrintSize", then a new menu on "Tool Settings appears to configure the wanted output size...
8 回复数
3,398 次查看
BlackNight
your problem is that no .elf has been created. And I don't see in your log any evidence that the linker gets called. Can you post your project (or at least the .project and .cproject files)?
Erich
3,398 次查看
arnogir
@: In fact your added line was the line that I already added without success. (This is the same that the User guide provided on Link in my first post)
I Have KDS v1.1.1, maybe I should update KDS version to 2.0.0 but is the project will be  compatible?
@Erich Styger: Please find asked file.
Many thanks
3,398 次查看
DavidS
I would recommend doing the update.
Changes should be minimal.
David
3,398 次查看
arnogir
I upgraded KDS to v2.0.0.
And then Size don't work again.
I test to set Post-Build step with:
"C:\Test.bat"
This file is a simple file:
echo "TEST POST Build command!!!!!!!!!!!!!!!"
copy c:\apps\cplus.elf  c:\apps\test.elf
pause
But console end always with following:
arm-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard [...]
Info: Parallel threads used: 4
08:04:03 Build Finished (took 25s.16ms)
Then it seem that is the post build command which is not executed, because nothing written in console and the file cplus.elf is not copy to test.elf...
:smileyshocked:
3,399 次查看
arnogir
3,398 次查看
BlackNight
It seems to me that this project has not been created with File > New > Kinetis Design Studio Project menu item?
Erich
3,397 次查看
arnogir
I'm started from an basic example project provided with MQX.
3,396 次查看
DavidS
Hi Arno,
In my KDS2.0.0 project properties setting I have added the following "arm-none-eabi-size" --format=berkeley $ :
When I compile I get the following:
'Invoking: Cross ARM C Linker'
arm-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall -Wno-missing-braces -g3 -gdwarf-2 -gstrict-dwarf -gstrict-dwarf -gstrict-dwarf -T C:/Freescale/KSDK_1.1.0/rtos/mqx/mqx/examples/event/build/kds/event_frdmk64f/../../../../../../../../platform/linker/MK64F12/gcc/MK64FN1M0xxx12_flash.ld -nostartfiles -nodefaultlibs -Xlinker --gc-sections -Wl,-Map,"event.map" -Xlinker --cref -Xlinker -static -Xlinker -z -Xlinker muldefs -Xlinker --undefined=__isr_vector -Xlinker --defsym=__stack_size__=0x200 -Xlinker --defsym=__heap_size__=0x200 -o "event.elf" -Xlinker --start-group ./Sources/event.o ./KSDK_Files/gpio_pins.o ./KSDK_Files/hardware_init.o ./KSDK_Files/pin_mux.o ./Debug_Console/fsl_debug_console.o ./Debug_Console/fsl_misc_utilities.o ./Debug_Console/print_scan.o ./BSP_Files/init_bsp.o ./BSP_Files/mqx_main.o C:/Freescale/KSDK_1.1.0/rtos/mqx/mqx/examples/event/build/kds/event_frdmk64f/../../../../../../../../lib/ksdk_mqx_lib/kds/K64F12/Debug/libksdk_platform_mqx.a C:/Freescale/KSDK_1.1.0/rtos/mqx/mqx/examples/event/build/kds/event_frdmk64f/../../../../../../lib/frdmk64f.kds/debug/mqx_stdlib/lib_mqx_stdlib.a C:/Freescale/KSDK_1.1.0/rtos/mqx/mqx/examples/event/build/kds/event_frdmk64f/../../../../../../lib/frdmk64f.kds/debug/mqx/lib_mqx.a C:/Freescale/KDS_2.0.0/eclipse//../toolchain/lib/gcc/arm-none-eabi/4.8.0/m4/fp/v4-sp-d16/libgcc.a C:/Freescale/KDS_2.0.0/eclipse//../toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libc.a C:/Freescale/KDS_2.0.0/eclipse//../toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libsupc++.a C:/Freescale/KDS_2.0.0/eclipse//../toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libm.a -Xlinker --end-group
'Finished building target: event.elf'
make --no-print-directory post-build
"arm-none-eabi-size" --format=berkeley event.elf
text data bss dec hex filename
61972 2284 2700 66956 1058c event.elf
10:53:53 Build Finished (took 3s.489ms)
Hope this helps.
David
