Any way to determine RAM usage at runtime?
2,011 次查看
mike1974
Can the KDS debugger tell me RAM usage?  I know that looking at the .map file could be helpful, but I'm allocating some stuff dynamically at runtime, and I would like to know how much I have left after doing so.
1,757 次查看
BlackNight
That depends on how you are allocating dynamically your objects. You would need a function from that heap management to tell you the amount of free heap. If you are usinig FreeRTOS, it will report it to you with heap size with xPortFreeHeapSize().
1,758 次查看
BlackNight
1,757 次查看
mike1974
Thank you Erich.
By the way, I don't see a memory usage summary in the .map file.  It seems I will have to extract it manually by searching/looking at each sections usage.
Do you know of a better way?
