Any way to determine RAM usage at runtime?
3,004件の閲覧回数
mike1974
Can the KDS debugger tell me RAM usage?  I know that looking at the .map file could be helpful, but I'm allocating some stuff dynamically at runtime, and I would like to know how much I have left after doing so.
2,750件の閲覧回数
BlackNight
That depends on how you are allocating dynamically your objects. You would need a function from that heap management to tell you the amount of free heap. If you are usinig FreeRTOS, it will report it to you with heap size with xPortFreeHeapSize().
3 返答(返信)
2,751件の閲覧回数
BlackNight
2,750件の閲覧回数
mike1974
Thank you Erich.
By the way, I don't see a memory usage summary in the .map file.  It seems I will have to extract it manually by searching/looking at each sections usage.
Do you know of a better way?
