Accelerometer example/sample code for FRDM-KL27Z
3,516 次查看
evelamartinez
Hi folks,
please, do you have any accelerometer example/sample code for FRDM-KL27Z?
Thank you,
Evela
2,724 次查看
EarlOrlando
Senior Contributor II
Hello Evela,
I recommend you to take a look into the example located in the KSDK 1.2.0 installation folder C:\Freescale\KSDK_1.2.0\examples\frdmk64f\demo_apps\bubble_level_ftm which contains an example for the same accelerometer that is included in the FRDM-KL27Z. This example shows how to interface the accelerometer with your kinetis MCU. This demo is written in KSDK so its portability is very transparent, you just need to configure the I2C pins to be compliance.
I hope this helps.
I remain at your service.
Earl Orlando.
2,725 次查看
EarlOrlando
Hello Evela,
I hope this helps.
Earl Orlando.
2,724 次查看
lucasrangit
I went to https://mcuxpresso.nxp.com/en/example-projects  and downloaded the bubble example for the FRDM-KL27Z. The project imported and builds but the debug configurations did not. I have to manually re-create them. I'll make a new ticket regarding this.
