New Kinetis Design Studio V3.0.0 available
Greetings,
the new Kinetis Design Studio V3.0.0 is available in the download section of the Freescale web:
http://www.freescale.com/kds
Kinetis Design Studio is free of charge and unlimited.
What's New
  • New Eclipse Luna 4.4 IDE
  • Added Mac OS X (10.10, "Yosemite") host operating system support with Segger J-Link.
  • Added CMSIS-SVD Peripheral Register viewer.
  • New 'Welcome' view
  • New GNU ARM Embedded (launchpad) toolchain, reducing memory footprint especially for small devices.
  • New upgrade/migration assistant to migrate projects to V3.0.0.
  • Updated and extended Segger and P&E debugging support: attach to running target, semihosting and advanced flash programming features.
  • New Processor Expert V3.0 with multiple repository support and simplified Kinetis SDK usage and ability to generate projects for IAR and Keil.
  • Updated New Project Wizard (NPW) for simpler project creation.
  • Updated GNU ARM Eclipse plugins, multiple tool chain configurations.
  • Aligned and optimized for Kinetis SDK v1.2
  • New Device Support: see attached release notes (Rev 1).
Additional Kinetis SDK Device Support
For full/additional device support:
  1. Download the Kinetis SDK v1.2 from Software Development Kit for Kinetis MCUs|Freescale
  2. Install the Kinetis SDK
  3. Add Kinetis SDK v1.2 to KDS: Use the menu Help > Install New Software and use C:\Freescale\KSDK_1.2.0\tools\eclipse_update\KSDK_1.2.0_Eclipse_Update (KSDK path on windows)
See https://community.freescale.com/docs/DOC-103698 for additional details, especially about porting KDS v2.0.0 projects to the GNU ARM Embedded (launchpad) tools.
Screenshots of new features
Mac OS X support:
New Workspace Welcome view:
Kinetis SDK selection in New Project Wizard:
Ability to generate Processor Expert (Microcontroller Driver Suite) external projects for IAR and Keil:
Eclipse Luna 4.4, e.g. Split Editor Views:
Processor Expert V3.0 and multiple component repositories:
Upgrade assistant to migrate projects from KDS V1.x/V2.0.0 to V3.0.0:
Multiple tool chain configurations:
Peripheral Register Viewer:
JTAG Daisy Chaining:
Advanced Flash Programming Options:
Attach to running target:
And finally, for the 'lovers of the dark side' :-): Eclipse Luna 'Dark' style:
Enjoy :-)
Comments
Hi Erich,
Is the mac version already available?
In the KDS Download webpage there is no link for mac.
Hi Ali,
I appologize for that, I have realized that too. Working with the web team to get that fixed. Will post a comment here when it is fixed.
Erich
Hi Ali,
the web download has been fixed, and the Mac OS X installer is available now.
Erich
Thanks Erich!
-Ali
Hi Erich,
The new KDS seems great so far! In the release notes for accessing the Register View, I think they meant to say:
"Window > Show View > Other > Debug" instead of Help > Show Views ...
-Angus
Hi Erich
kinetis M not support for kinetis dising 3.0
andres
Hi Andres,
yes, Kinetis M is not supported in KDS, because it is not supported in the Kinetis SDK (yet).
Erich
Hi Angus,
thanks for reporting this. This already has been fixed in the Rev1 version of the release notes (attached to this page). The installation comes with Rev0 which indeed has that error in it.
Erich
Hi Erich
1. Thanks for the MacOSX version!
2. What about support for Vybrid processors? For the standalone Driver Suite a Vybrid plugin exists, any plans to integrate into the latest KDS/SDK?
hi Erich
then that can be programmed Kinetis M,using process experts
thanks
Hi Robert,
there are currently no plans to have Vybrid added to Kinetis Design Studio.
Erich
Hi Erich, the Linux version .bin file cannot be installed.
./Kinetis\ Design\ Studio\ installer\ for\ Linux\ 64-bit\ DEB\ 3.0.0.bin
./Kinetis Design Studio installer for Linux 64-bit DEB 3.0.0.bin: line 1: syntax error near unexpected token `newline'
./Kinetis Design Studio installer for Linux 64-bit DEB 3.0.0.bin: line 1: `!<arch>'
mv ./Kinetis\ Design\ Studio\ installer\ for\ Linux\ 64-bit\ DEB\ 3.0.0.bin ./Kinetis\ Design\ Studio\ installer\ for\ Linux\ 64-bit\ DEB\ 3.0.0.deb
sudo dpkg -i ./Kinetis\ Design\ Studio\ installer\ for\ Linux\ 64-bit\ DEB\ 3.0.0.deb
Thanks. I wish Freescale had used .deb instead of .bin for Debian file.
Hi, If want to develop a commercial product can I do it with kinetis studio? Do I have to pay if I want to use it for the purpose?
Kinetis Design Studio can be used for commercial purposes, it has not limits except that it can be used for Freescale devices only.
Hi Erich,
My mac version is 10.11.1.
When I open KDS and select a workspace I can't click any buttons. It was stuck.
are using El Capitan? If so, then it could be this problem (with solution):
KDS on OS X El Capitan (Beta)
I hope this helps,
Erich
It works. Thanks!
Hi Erich,
Using "Init_GPIO" it is possible to set pull-up or pull-down resistor in KDS V3.0.0?
I found examples using CodeWarrior!
Arnaldo
Hi Arnaldo,
yes, this is possible with Processor Expert projects.
Erich
%3CLINGO-SUB%20id%3D%22lingo-sub-1114055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENew%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGreetings%2C%3C%2FP%3E%3CP%3Ethe%20new%20Kinetis%20Design%20Studio%20V3.0.0%20is%20available%20in%20the%20download%20section%20of%20the%20Freescale%20web%3A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fkds%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fkds%3C%2FA%3E%3C%2FP%3E%3CP%3EKinetis%20Design%20Studio%20is%20free%20of%20charge%20and%20unlimited.%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH1%20id%3D%22toc-hId-381527820%22%20id%3D%22toc-hId-1296885932%22%3EWhat's%20New%3C%2FH1%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3ENew%20%3CSTRONG%3EEclipse%20Luna%3C%2FSTRONG%3E%204.4%20IDE%3C%2FLI%3E%3CLI%3EAdded%20%3CSTRONG%3EMac%20OS%20X%3C%2FSTRONG%3E%20(10.10%2C%20%22Yosemite%22)%20host%20operating%20system%20support%20with%20Segger%20J-Link.%3C%2FLI%3E%3CLI%3EAdded%20%3CSTRONG%3ECMSIS-SVD%20Peripheral%20Register%20viewer%3C%2FSTRONG%3E.%3C%2FLI%3E%3CLI%3ENew%20'%3CSTRONG%3EWelcome%3C%2FSTRONG%3E'%20view%3C%2FLI%3E%3CLI%3ENew%20%3CSTRONG%3EGNU%20ARM%20Embedded%20(launchpad)%3C%2FSTRONG%3E%20toolchain%2C%20reducing%20memory%20footprint%20especially%20for%20small%20devices.%3C%2FLI%3E%3CLI%3ENew%20%3CSTRONG%3Eupgrade%2Fmigration%20assistant%3C%2FSTRONG%3E%20to%20migrate%20projects%20to%20V3.0.0.%3C%2FLI%3E%3CLI%3EUpdated%20and%20extended%20%3CSTRONG%3ESegger%3C%2FSTRONG%3E%20and%20%3CSTRONG%3EP%26amp%3BE%3C%2FSTRONG%3E%20debugging%20support%3A%20%3CSTRONG%3Eattach%20to%20running%20target%2C%20semihosting%20and%20advanced%20flash%20programming%20features%3C%2FSTRONG%3E.%3C%2FLI%3E%3CLI%3ENew%3CSTRONG%3E%20Processor%20Expert%20V3.0%3C%2FSTRONG%3E%20with%20%3CSTRONG%3Emultiple%20repository%3C%2FSTRONG%3E%20support%20and%20simplified%20Kinetis%20SDK%20usage%20and%20ability%20to%20generate%20projects%20for%20%3CSTRONG%3EIAR%3C%2FSTRONG%3E%20and%20%3CSTRONG%3EKeil%3C%2FSTRONG%3E.%3C%2FLI%3E%3CLI%3EUpdated%20%3CSTRONG%3ENew%20Project%20Wizard%3C%2FSTRONG%3E%20(NPW)%20for%20simpler%20project%20creation.%3C%2FLI%3E%3CLI%3EUpdated%20%3CSTRONG%3EGNU%20ARM%20Eclipse%3C%2FSTRONG%3E%20plugins%2C%20multiple%20tool%20chain%20configurations.%3C%2FLI%3E%3CLI%3EAligned%20and%20optimized%20for%20%3CSTRONG%3EKinetis%20SDK%20v1.2%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3ENew%20Device%20Support%3A%3C%2FSTRONG%3E%20see%20attached%20release%20notes%20(Rev%201).%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH3%20id%3D%22toc-hId--724862065%22%20id%3D%22toc-hId-190496047%22%3EAdditional%20Kinetis%20SDK%20Device%20Support%3C%2FH3%3E%3CP%3EFor%20full%2Fadditional%20device%20support%3A%3C%2FP%3E%3COL%3E%3CLI%3EDownload%20the%20Kinetis%20SDK%20v1.2%20from%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fksdk%22%20target%3D%22_blank%22%3ESoftware%20Development%20Kit%20for%20Kinetis%20MCUs%7CFreescale%3C%2FA%3E%3C%2FLI%3E%3CLI%3EInstall%20the%20Kinetis%20SDK%3C%2FLI%3E%3CLI%3EAdd%20Kinetis%20SDK%20v1.2%20to%20KDS%3A%20Use%20the%20menu%20%3CSTRONG%3E%3CEM%3EHelp%20%26gt%3B%20Install%20New%20Software%3C%2FEM%3E%3C%2FSTRONG%3E%20and%20use%20C%3A%5CFreescale%5CKSDK_1.2.0%5Ctools%5Ceclipse_update%5CKSDK_1.2.0_Eclipse_Update%20(KSDK%20path%20on%20windows)%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESee%20%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211213%22%20data-containertype%3D%2214%22%20data-objectid%3D%22103698%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103698%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-103698%3C%2FA%3E%20for%20additional%20details%2C%20especially%20about%20porting%20KDS%20v2.0.0%20projects%20to%20the%20GNU%20ARM%20Embedded%20(launchpad)%20tools.%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1061586190%22%20id%3D%22toc-hId-1976944302%22%3EScreenshots%20of%20new%20features%3C%2FH1%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMac%20OS%20X%20support%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222845_22845.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222845_22845.png%22%20style%3D%22width%3A%20702px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117690i4F775CDF81B9BAA0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222845_22845.png%22%20alt%3D%2222845_22845.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22845_22845.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20702px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13892i8F944FEA844F6E21%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3ENew%20Workspace%20Welcome%20view%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222844_22844.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222844_22844.png%22%20style%3D%22width%3A%20866px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117691i4C4E76FEFF4650AD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222844_22844.png%22%20alt%3D%2222844_22844.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22844_22844.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20866px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55645iF6D73732B21391F8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EKinetis%20SDK%20selection%20in%20New%20Project%20Wizard%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222839_22839.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222839_22839.png%22%20style%3D%22width%3A%20556px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117692i1C7C9B9D08945B2B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222839_22839.png%22%20alt%3D%2222839_22839.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22839_22839.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20556px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13893iF0858F5B8A4456A2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAbility%20to%20generate%20Processor%20Expert%20(Microcontroller%20Driver%20Suite)%20external%20projects%20for%20IAR%20and%20Keil%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222840_22840.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222840_22840.png%22%20style%3D%22width%3A%20473px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117693iB4BC0AC0C9830368%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222840_22840.png%22%20alt%3D%2222840_22840.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22840_22840.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20473px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13894i7D5E5A9A7187DD4C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EEclipse%20Luna%204.4%2C%20e.g.%20Split%20Editor%20Views%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222846_22846.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222846_22846.png%22%20style%3D%22width%3A%20502px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117694i18831E448AB481E4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222846_22846.png%22%20alt%3D%2222846_22846.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22846_22846.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20502px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13891iC8CE3604AA188338%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222847_22847.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222847_22847.png%22%20style%3D%22width%3A%20866px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117695i9D678D5C246344F6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222847_22847.png%22%20alt%3D%2222847_22847.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22847_22847.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20866px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13890iE4C1CABCEEB8C5A7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EProcessor%20Expert%20V3.0%20and%20multiple%20component%20repositories%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222849_22849.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222849_22849.png%22%20style%3D%22width%3A%20972px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117696i8D49C4530341EFC6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222849_22849.png%22%20alt%3D%2222849_22849.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22849_22849.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20972px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19942i5C46E68B6E640D81%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222850_22850.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222850_22850.png%22%20style%3D%22width%3A%20628px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117697i24057F573B6501EE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222850_22850.png%22%20alt%3D%2222850_22850.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22850_22850.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20628px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13895iBF2BE0FF45DE28E4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EUpgrade%20assistant%20to%20migrate%20projects%20from%20KDS%20V1.x%2FV2.0.0%20to%20V3.0.0%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222851_22851.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222851_22851.png%22%20style%3D%22width%3A%20240px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117698i8F1F3FD51C758B28%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222851_22851.png%22%20alt%3D%2222851_22851.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22851_22851.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20240px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13896iEE52D15A3124015D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222852_22852.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222852_22852.png%22%20style%3D%22width%3A%20396px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117699iE348177E9D1F278C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222852_22852.png%22%20alt%3D%2222852_22852.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22852_22852.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20396px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13897i9BA9B34489B8EFBB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMultiple%20tool%20chain%20configurations%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222853_22853.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222853_22853.png%22%20style%3D%22width%3A%20561px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117700i07327737981D0267%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222853_22853.png%22%20alt%3D%2222853_22853.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22853_22853.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20561px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13898iD79F2D0B1D939F13%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22%22%20class%3D%22jiveImage%22%20style%3D%22max-width%3A%201200px%3B%20max-height%3A%20900px%3B%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EPeripheral%20Register%20Viewer%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222855_22855.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222855_22855.png%22%20style%3D%22width%3A%20888px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117701iC8C84F3E0265A61A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222855_22855.png%22%20alt%3D%2222855_22855.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22855_22855.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20888px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13899iB031B3472C0470E6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EJTAG%20Daisy%20Chaining%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222856_22856.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222856_22856.png%22%20style%3D%22width%3A%20830px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117702i56C9FC1F992C033E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222856_22856.png%22%20alt%3D%2222856_22856.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22856_22856.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20830px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F51773i0751077ED5C596D6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAdvanced%20Flash%20Programming%20Options%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222858_22858.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222858_22858.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117703i40287443706FCAE9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222858_22858.png%22%20alt%3D%2222858_22858.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22858_22858.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13900i605A7010A521121A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_10.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAttach%20to%20running%20target%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222857_22857.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222857_22857.png%22%20style%3D%22width%3A%20680px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117704iB5FD061E3E9968D8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222857_22857.png%22%20alt%3D%2222857_22857.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22857_22857.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20680px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13901iEC0A7C36476DD9CE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAnd%20finally%2C%20for%20the%20'lovers%20of%20the%20dark%20side'%20%3A-)%3A%20Eclipse%20Luna%20'Dark'%20style%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222860_22860.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222860_22860.png%22%20style%3D%22width%3A%20701px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117705i20383BB215FFE521%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222860_22860.png%22%20alt%3D%2222860_22860.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22860_22860.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20701px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55606i6E31EAB7275B6306%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EEnjoy%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Arnaldo%2C%3C%2FP%3E%3CP%3Eyes%2C%20this%20is%20possible%20with%20Processor%20Expert%20projects.%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Erich%2C%3C%2FP%3E%3CP%3EUsing%20%22Init_GPIO%22%20it%20is%20possible%20to%20set%20pull-up%20or%20pull-down%20resistor%20in%20KDS%20V3.0.0%3F%3C%2FP%3E%3CP%3EI%20found%20examples%20using%20CodeWarrior!%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EArnaldo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20works.%20Thanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3Eare%20using%20El%20Capitan%3F%20If%20so%2C%20then%20it%20could%20be%20this%20problem%20(with%20solution)%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F364331%22%20target%3D%22_blank%22%3EKDS%20on%20OS%20X%20El%20Capitan%20(Beta)%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20hope%20this%20helps%2C%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EHi%20Erich%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EMy%20mac%20version%20is%2010.11.1.%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EWhen%20I%20open%20KDS%20and%20select%20a%20workspace%20I%20can't%20click%20any%20buttons.%20It%20was%20stuck.%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EKinetis%20Design%20Studio%20can%20be%20used%20for%20commercial%20purposes%2C%20it%20has%20not%20limits%20except%20that%20it%20can%20be%20used%20for%20Freescale%20devices%20only.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%20Hi%2C%20If%20want%20to%20develop%20a%20commercial%20product%20can%20I%20do%20it%20with%20kinetis%20studio%3F%20Do%20I%20have%20to%20pay%20if%20I%20want%20to%20use%20it%20for%20the%20purpose%3F%20%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks.%20I%20wish%20Freescale%20had%20used%20.deb%20instead%20of%20.bin%20for%20Debian%20file.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Emv%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E.%2FKinetis%5C%20Design%5C%20Studio%5C%20installer%5C%20for%5C%20Linux%5C%2064-bit%5C%20DEB%5C%203.0.0.bin%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E.%2FKinetis%5C%20Design%5C%20Studio%5C%20installer%5C%20for%5C%20Linux%5C%2064-bit%5C%20DEB%5C%203.0.0.deb%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Esudo%20dpkg%20-i%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E.%2FKinetis%5C%20Design%5C%20Studio%5C%20installer%5C%20for%5C%20Linux%5C%2064-bit%5C%20DEB%5C%203.0.0.deb%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Erich%2C%20the%20Linux%20version%20.bin%20file%20cannot%20be%20installed.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.%2FKinetis%5C%20Design%5C%20Studio%5C%20installer%5C%20for%5C%20Linux%5C%2064-bit%5C%20DEB%5C%203.0.0.bin%20%3C%2FP%3E%3CP%3E.%2FKinetis%20Design%20Studio%20installer%20for%20Linux%2064-bit%20DEB%203.0.0.bin%3A%20line%201%3A%20syntax%20error%20near%20unexpected%20token%20%60newline'%3C%2FP%3E%3CP%3E.%2FKinetis%20Design%20Studio%20installer%20for%20Linux%2064-bit%20DEB%203.0.0.bin%3A%20line%201%3A%20%60!%3CARCH%3E'%3C%2FARCH%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Robert%2C%3C%2FP%3E%3CP%3Ethere%20are%20currently%20no%20plans%20to%20have%20Vybrid%20added%20to%20Kinetis%20Design%20Studio.%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%20Erich%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ethen%20that%20can%20be%20programmed%20Kinetis%20M%2Cusing%20process%20experts%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ethanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Erich%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20Thanks%20for%20the%20MacOSX%20version!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20What%20about%20support%20for%20Vybrid%20processors%3F%20For%20the%20standalone%20Driver%20Suite%20a%20Vybrid%20plugin%20exists%2C%20any%20plans%20to%20integrate%20into%20the%20latest%20KDS%2FSDK%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vybrid.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vybrid.png%22%20style%3D%22width%3A%20211px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F9008i8834B7F2AE14100C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Vybrid.png%22%20alt%3D%22Vybrid.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EVybrid.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Angus%2C%3C%2FP%3E%3CP%3Ethanks%20for%20reporting%20this.%20This%20already%20has%20been%20fixed%20in%20the%20Rev1%20version%20of%20the%20release%20notes%20(attached%20to%20this%20page).%20The%20installation%20comes%20with%20Rev0%20which%20indeed%20has%20that%20error%20in%20it.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Andres%2C%3C%2FP%3E%3CP%3Eyes%2C%20Kinetis%20M%20is%20not%20supported%20in%20KDS%2C%20because%20it%20is%20not%20supported%20in%20the%20Kinetis%20SDK%20(yet).%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Erich%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ekinetis%20M%20not%20support%20for%20kinetis%20dising%203.0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eandres%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Erich%2C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20new%20KDS%20seems%20great%20so%20far!%20In%20the%20release%20notes%20for%20accessing%20the%20Register%20View%2C%20I%20think%20they%20meant%20to%20say%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%22%3CSTRONG%3EWindow%20%26gt%3B%20Show%20View%20%26gt%3B%20Other%20%26gt%3B%20Debug%3C%2FSTRONG%3E%22%20instead%20of%20Help%20%26gt%3B%20Show%20Views%20...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Angus%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20Erich!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Ali%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Ali%2C%3C%2FP%3E%3CP%3Ethe%20web%20download%20has%20been%20fixed%2C%20and%20the%20Mac%20OS%20X%20installer%20is%20available%20now.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Ali%2C%3C%2FP%3E%3CP%3EI%20appologize%20for%20that%2C%20I%20have%20realized%20that%20too.%20Working%20with%20the%20web%20team%20to%20get%20that%20fixed.%20Will%20post%20a%20comment%20here%20when%20it%20is%20fixed.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20New%20Kinetis%20Design%20Studio%20V3.0.0%20available%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Erich%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIs%20the%20mac%20version%20already%20available%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIn%20the%20KDS%20Download%20webpage%20there%20is%20no%20link%20for%20mac.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EAli%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kds.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kds.png%22%20style%3D%22width%3A%20755px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F49409i8374907A0087CA58%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22kds.png%22%20alt%3D%22kds.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ekds.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎05-06-2015 04:16 AM
Updated by:
