New Kinetis Design Studio V3.0.0 available
Greetings,
the new Kinetis Design Studio V3.0.0 is available in the download section of the Freescale web:
http://www.freescale.com/kds
Kinetis Design Studio is free of charge and unlimited.
What's New
  • New Eclipse Luna 4.4 IDE
  • Added Mac OS X (10.10, "Yosemite") host operating system support with Segger J-Link.
  • Added CMSIS-SVD Peripheral Register viewer.
  • New 'Welcome' view
  • New GNU ARM Embedded (launchpad) toolchain, reducing memory footprint especially for small devices.
  • New upgrade/migration assistant to migrate projects to V3.0.0.
  • Updated and extended Segger and P&E debugging support: attach to running target, semihosting and advanced flash programming features.
  • New Processor Expert V3.0 with multiple repository support and simplified Kinetis SDK usage and ability to generate projects for IAR and Keil.
  • Updated New Project Wizard (NPW) for simpler project creation.
  • Updated GNU ARM Eclipse plugins, multiple tool chain configurations.
  • Aligned and optimized for Kinetis SDK v1.2
  • New Device Support: see attached release notes (Rev 1).
Additional Kinetis SDK Device Support
For full/additional device support:
  1. Download the Kinetis SDK v1.2 from Software Development Kit for Kinetis MCUs|Freescale
  2. Install the Kinetis SDK
  3. Add Kinetis SDK v1.2 to KDS: Use the menu Help > Install New Software and use C:\Freescale\KSDK_1.2.0\tools\eclipse_update\KSDK_1.2.0_Eclipse_Update (KSDK path on windows)
See https://community.freescale.com/docs/DOC-103698 for additional details, especially about porting KDS v2.0.0 projects to the GNU ARM Embedded (launchpad) tools.
Screenshots of new features
Mac OS X support:
New Workspace Welcome view:
Kinetis SDK selection in New Project Wizard:
Ability to generate Processor Expert (Microcontroller Driver Suite) external projects for IAR and Keil:
Eclipse Luna 4.4, e.g. Split Editor Views:
Processor Expert V3.0 and multiple component repositories:
Upgrade assistant to migrate projects from KDS V1.x/V2.0.0 to V3.0.0:
Multiple tool chain configurations:
Peripheral Register Viewer:
JTAG Daisy Chaining:
Advanced Flash Programming Options:
Attach to running target:
And finally, for the 'lovers of the dark side' :-): Eclipse Luna 'Dark' style:
Enjoy :-)
附件
评论
Hi Erich,
Is the mac version already available?
In the KDS Download webpage there is no link for mac.
Hi Ali,
I appologize for that, I have realized that too. Working with the web team to get that fixed. Will post a comment here when it is fixed.
Erich
Hi Ali,
the web download has been fixed, and the Mac OS X installer is available now.
Erich
Thanks Erich!
-Ali
Hi Erich,
The new KDS seems great so far! In the release notes for accessing the Register View, I think they meant to say:
"Window > Show View > Other > Debug" instead of Help > Show Views ...
-Angus
Hi Erich
kinetis M not support for kinetis dising 3.0
andres
Hi Andres,
yes, Kinetis M is not supported in KDS, because it is not supported in the Kinetis SDK (yet).
Erich
Hi Angus,
thanks for reporting this. This already has been fixed in the Rev1 version of the release notes (attached to this page). The installation comes with Rev0 which indeed has that error in it.
Erich
Hi Erich
1. Thanks for the MacOSX version!
2. What about support for Vybrid processors? For the standalone Driver Suite a Vybrid plugin exists, any plans to integrate into the latest KDS/SDK?
hi Erich
then that can be programmed Kinetis M,using process experts
thanks
Hi Robert,
there are currently no plans to have Vybrid added to Kinetis Design Studio.
Erich
Hi Erich, the Linux version .bin file cannot be installed.
./Kinetis\ Design\ Studio\ installer\ for\ Linux\ 64-bit\ DEB\ 3.0.0.bin
./Kinetis Design Studio installer for Linux 64-bit DEB 3.0.0.bin: line 1: syntax error near unexpected token `newline'
./Kinetis Design Studio installer for Linux 64-bit DEB 3.0.0.bin: line 1: `!<arch>'
mv ./Kinetis\ Design\ Studio\ installer\ for\ Linux\ 64-bit\ DEB\ 3.0.0.bin ./Kinetis\ Design\ Studio\ installer\ for\ Linux\ 64-bit\ DEB\ 3.0.0.deb
sudo dpkg -i ./Kinetis\ Design\ Studio\ installer\ for\ Linux\ 64-bit\ DEB\ 3.0.0.deb
Thanks. I wish Freescale had used .deb instead of .bin for Debian file.
Hi, If want to develop a commercial product can I do it with kinetis studio? Do I have to pay if I want to use it for the purpose?
Kinetis Design Studio can be used for commercial purposes, it has not limits except that it can be used for Freescale devices only.
Hi Erich,
My mac version is 10.11.1.
When I open KDS and select a workspace I can't click any buttons. It was stuck.
are using El Capitan? If so, then it could be this problem (with solution):
KDS on OS X El Capitan (Beta)
I hope this helps,
Erich
It works. Thanks!
Hi Erich,
Using "Init_GPIO" it is possible to set pull-up or pull-down resistor in KDS V3.0.0?
I found examples using CodeWarrior!
Arnaldo
Hi Arnaldo,
yes, this is possible with Processor Expert projects.
Erich
%3CLINGO-SUB%20id%3D%22lingo-sub-1114055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%85%A8%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%96%B0%E7%9A%84%20Kinetis%20Design%20Studio%20V3.0.0%20%E5%8F%AF%E5%9C%A8%20Freescale%20%E7%BD%91%E7%AB%99%E7%9A%84%E4%B8%8B%E8%BD%BD%E9%83%A8%E5%88%86%E6%89%BE%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fkds%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fkds%3C%2FA%3E%3C%2FP%3E%3CP%3EKinetis%20Design%20Studio%20%E6%98%AF%E5%85%8D%E8%B4%B9%E4%B8%94%E6%97%A0%E9%99%90%E5%88%B6%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH1%20id%3D%22toc-hId-381527820%22%20id%3D%22toc-hId-1303176664%22%3E%E6%96%B0%E7%89%B9%E6%80%A7%3C%2FH1%3E%3CUL%20style%3D%22list-style-type%3A%20disc%3B%22%3E%3CLI%3E%E6%96%B0%E7%9A%84%3CSTRONG%3EEclipse%20Luna%3C%2FSTRONG%3E%204.4%20IDE%3C%2FLI%3E%3CLI%3E%E6%B7%BB%E5%8A%A0%E4%BA%86%E9%80%9A%E8%BF%87%20Segger%20J-Link%20%E6%94%AF%E6%8C%81%E7%9A%84%3CSTRONG%3EMac%20OS%20X%3C%2FSTRONG%3E%20%EF%BC%8810.10%EF%BC%8C%E2%80%9CYosemite%E2%80%9D%EF%BC%89%E4%B8%BB%E6%9C%BA%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%B7%BB%E5%8A%A0%E4%BA%86%3CSTRONG%3ECMSIS-SVD%20%E5%A4%96%E8%AE%BE%E5%AF%84%E5%AD%98%E5%99%A8%E6%9F%A5%E7%9C%8B%E5%99%A8%3C%2FSTRONG%3E%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%96%B0%E7%9A%84%E2%80%9C%3CSTRONG%3E%E6%AC%A2%E8%BF%8E%3C%2FSTRONG%3E%E2%80%9D%E8%A7%86%E5%9B%BE%3C%2FLI%3E%3CLI%3E%E6%96%B0%E7%9A%84%3CSTRONG%3EGNU%20ARM%20%E5%B5%8C%E5%85%A5%E5%BC%8F%EF%BC%88%E5%90%AF%E5%8A%A8%E6%9D%BF%EF%BC%89%3C%2FSTRONG%3E%E5%B7%A5%E5%85%B7%E9%93%BE%EF%BC%8C%E5%87%8F%E5%B0%91%E5%86%85%E5%AD%98%E5%8D%A0%E7%94%A8%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E5%AF%B9%E4%BA%8E%E5%B0%8F%E5%9E%8B%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%96%B0%E7%9A%84%3CSTRONG%3E%E5%8D%87%E7%BA%A7%2F%E8%BF%81%E7%A7%BB%E5%8A%A9%E6%89%8B%EF%BC%8C%3C%2FSTRONG%3E%E7%94%A8%E4%BA%8E%E5%B0%86%E9%A1%B9%E7%9B%AE%E8%BF%81%E7%A7%BB%E5%88%B0%20V3.0.0%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%9B%B4%E6%96%B0%E5%92%8C%E6%89%A9%E5%B1%95%E4%BA%86%3CSTRONG%3ESegger%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EP%26amp%3BE%3C%2FSTRONG%3E%E8%B0%83%E8%AF%95%E6%94%AF%E6%8C%81%EF%BC%9A%3CSTRONG%3E%E9%99%84%E5%8A%A0%E5%88%B0%E8%BF%90%E8%A1%8C%E7%9B%AE%E6%A0%87%E3%80%81%E5%8D%8A%E4%B8%BB%E6%9C%BA%E5%92%8C%E9%AB%98%E7%BA%A7%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E5%8A%9F%E8%83%BD%3C%2FSTRONG%3E%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%96%B0%E7%9A%84%3CSTRONG%3EProcessor%20Expert%20V3.0%3C%2FSTRONG%3E%E5%85%B7%E6%9C%89%3CSTRONG%3E%E5%A4%9A%E4%B8%AA%E5%AD%98%E5%82%A8%E5%BA%93%3C%2FSTRONG%3E%E6%94%AF%E6%8C%81%E5%92%8C%E7%AE%80%E5%8C%96%E7%9A%84%20Kinetis%20SDK%20%E4%BD%BF%E7%94%A8%E4%BB%A5%E5%8F%8A%E4%B8%BA%3CSTRONG%3EIAR%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EKeil%3C%2FSTRONG%3E%E7%94%9F%E6%88%90%E9%A1%B9%E7%9B%AE%E7%9A%84%E8%83%BD%E5%8A%9B%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%9B%B4%E6%96%B0%E4%BA%86%3CSTRONG%3E%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%90%91%E5%AF%BC%3C%2FSTRONG%3E%EF%BC%88NPW%EF%BC%89%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%9B%B4%E7%AE%80%E5%8D%95%E5%9C%B0%E5%88%9B%E5%BB%BA%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%9B%B4%E6%96%B0%E4%BA%86%3CSTRONG%3EGNU%20ARM%20Eclipse%3C%2FSTRONG%3E%E6%8F%92%E4%BB%B6%EF%BC%8C%E5%A4%9A%E7%A7%8D%E5%B7%A5%E5%85%B7%E9%93%BE%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FLI%3E%3CLI%3E%E9%92%88%E5%AF%B9%3CSTRONG%3EKinetis%20SDK%20v1.2%3C%2FSTRONG%3E%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%95%B4%E5%92%8C%E4%BC%98%E5%8C%96%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E6%96%B0%E8%AE%BE%E5%A4%87%E6%94%AF%E6%8C%81%EF%BC%9A%3C%2FSTRONG%3E%E8%AF%B7%E5%8F%82%E9%98%85%E9%99%84%E4%BB%B6%E7%9A%84%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%88%201%EF%BC%89%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH3%20id%3D%22toc-hId--724862065%22%20id%3D%22toc-hId-196786779%22%3E%E9%99%84%E5%8A%A0%20Kinetis%20SDK%20%E8%AE%BE%E5%A4%87%E6%94%AF%E6%8C%81%3C%2FH3%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E5%AE%8C%E6%95%B4%2F%E9%99%84%E5%8A%A0%E8%AE%BE%E5%A4%87%E6%94%AF%E6%8C%81%EF%BC%9A%3C%2FP%3E%3COL%3E%3CLI%3E%E4%BB%8E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fksdk%22%20target%3D%22_blank%22%3EKinetis%20MCU%20%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%20%7C%20Freescale%3C%2FA%3E%E4%B8%8B%E8%BD%BD%20Kinetis%20SDK%20v1.2%3C%2FLI%3E%3CLI%3E%E5%AE%89%E8%A3%85Kinetis%20SDK%3C%2FLI%3E%3CLI%3E%E5%B0%86%20Kinetis%20SDK%20v1.2%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20KDS%EF%BC%9A%E4%BD%BF%E7%94%A8%E8%8F%9C%E5%8D%95%3CSTRONG%3E%3CEM%3E%E5%B8%AE%E5%8A%A9%20%26gt%3B%20%E5%AE%89%E8%A3%85%E6%96%B0%E8%BD%AF%E4%BB%B6%3C%2FEM%3E%3C%2FSTRONG%3E%E5%B9%B6%E4%BD%BF%E7%94%A8%20C%3A%5CFreescale%5CKSDK_1.2.0%5Ctools%5Ceclipse_update%5CKSDK_1.2.0_Eclipse_Update%EF%BC%88Windows%20%E4%B8%8A%E7%9A%84%20KSDK%20%E8%B7%AF%E5%BE%84%EF%BC%89%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%9C%89%E5%85%B3%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E6%9C%89%E5%85%B3%E5%B0%86%20KDS%20v2.0.0%20%E9%A1%B9%E7%9B%AE%E7%A7%BB%E6%A4%8D%E5%88%B0%20GNU%20ARM%20Embedded%EF%BC%88%E5%90%AF%E5%8A%A8%E6%9D%BF%EF%BC%89%E5%B7%A5%E5%85%B7%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211213%22%20data-containertype%3D%2214%22%20data-objectid%3D%22103698%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103698%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-103698%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1061586190%22%20id%3D%22toc-hId-1983235034%22%3E%E6%96%B0%E5%8A%9F%E8%83%BD%E6%88%AA%E5%9B%BE%3C%2FH1%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMac%20OS%20X%20%E6%94%AF%E6%8C%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222845_22845.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222845_22845.png%22%20style%3D%22width%3A%20702px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117690i4F775CDF81B9BAA0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222845_22845.png%22%20alt%3D%2222845_22845.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22845_22845.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20702px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13892i8F944FEA844F6E21%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%96%B0%E7%9A%84%E5%B7%A5%E4%BD%9C%E5%8C%BA%E6%AC%A2%E8%BF%8E%E8%A7%86%E5%9B%BE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222844_22844.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222844_22844.png%22%20style%3D%22width%3A%20866px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117691i4C4E76FEFF4650AD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222844_22844.png%22%20alt%3D%2222844_22844.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22844_22844.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20866px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55645iF6D73732B21391F8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%90%91%E5%AF%BC%E4%B8%AD%E7%9A%84%20Kinetis%20SDK%20%E9%80%89%E6%8B%A9%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222839_22839.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222839_22839.png%22%20style%3D%22width%3A%20556px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117692i1C7C9B9D08945B2B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222839_22839.png%22%20alt%3D%2222839_22839.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22839_22839.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20556px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13893iF0858F5B8A4456A2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E8%83%BD%E5%A4%9F%E4%B8%BA%20IAR%20%E5%92%8C%20Keil%20%E7%94%9F%E6%88%90%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%EF%BC%88%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%A5%97%E4%BB%B6%EF%BC%89%E5%A4%96%E9%83%A8%E9%A1%B9%E7%9B%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222840_22840.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222840_22840.png%22%20style%3D%22width%3A%20473px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117693iB4BC0AC0C9830368%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222840_22840.png%22%20alt%3D%2222840_22840.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22840_22840.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20473px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13894i7D5E5A9A7187DD4C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%20Eclipse%20Luna%204.4%E6%8B%86%E5%88%86%E7%BC%96%E8%BE%91%E5%99%A8%E8%A7%86%E5%9B%BE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222846_22846.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222846_22846.png%22%20style%3D%22width%3A%20502px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117694i18831E448AB481E4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222846_22846.png%22%20alt%3D%2222846_22846.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22846_22846.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20502px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13891iC8CE3604AA188338%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222847_22847.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222847_22847.png%22%20style%3D%22width%3A%20866px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117695i9D678D5C246344F6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222847_22847.png%22%20alt%3D%2222847_22847.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22847_22847.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20866px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13890iE4C1CABCEEB8C5A7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EProcessor%20Expert%20V3.0%20%E5%92%8C%E5%A4%9A%E4%B8%AA%E7%BB%84%E4%BB%B6%E5%BA%93%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222849_22849.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222849_22849.png%22%20style%3D%22width%3A%20972px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117696i8D49C4530341EFC6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222849_22849.png%22%20alt%3D%2222849_22849.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22849_22849.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20972px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F19942i5C46E68B6E640D81%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222850_22850.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222850_22850.png%22%20style%3D%22width%3A%20628px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117697i24057F573B6501EE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222850_22850.png%22%20alt%3D%2222850_22850.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22850_22850.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20628px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13895iBF2BE0FF45DE28E4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%8D%87%E7%BA%A7%E5%8A%A9%E6%89%8B%E5%B0%86%E9%A1%B9%E7%9B%AE%E4%BB%8E%20KDS%20V1.x%2FV2.0.0%20%E8%BF%81%E7%A7%BB%E5%88%B0%20V3.0.0%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222851_22851.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222851_22851.png%22%20style%3D%22width%3A%20240px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117698i8F1F3FD51C758B28%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222851_22851.png%22%20alt%3D%2222851_22851.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22851_22851.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20240px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13896iEE52D15A3124015D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222852_22852.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222852_22852.png%22%20style%3D%22width%3A%20396px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117699iE348177E9D1F278C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222852_22852.png%22%20alt%3D%2222852_22852.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22852_22852.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_3.png%22%20style%3D%22width%3A%20396px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13897i9BA9B34489B8EFBB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_3.png%22%20alt%3D%22pastedImage_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%A4%9A%E7%A7%8D%E5%B7%A5%E5%85%B7%E9%93%BE%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222853_22853.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222853_22853.png%22%20style%3D%22width%3A%20561px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117700i07327737981D0267%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222853_22853.png%22%20alt%3D%2222853_22853.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22853_22853.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20561px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13898iD79F2D0B1D939F13%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22%22%20class%3D%22jiveImage%22%20style%3D%22max-width%3A%201200px%3B%20max-height%3A%20900px%3B%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%A4%96%E8%AE%BE%E5%AF%84%E5%AD%98%E5%99%A8%E6%9F%A5%E7%9C%8B%E5%99%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222855_22855.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222855_22855.png%22%20style%3D%22width%3A%20888px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117701iC8C84F3E0265A61A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222855_22855.png%22%20alt%3D%2222855_22855.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22855_22855.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20888px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13899iB031B3472C0470E6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EJTAG%E8%8F%8A%E8%8A%B1%E9%93%BE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222856_22856.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222856_22856.png%22%20style%3D%22width%3A%20830px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117702i56C9FC1F992C033E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222856_22856.png%22%20alt%3D%2222856_22856.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22856_22856.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20830px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F51773i0751077ED5C596D6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E9%AB%98%E7%BA%A7%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E9%80%89%E9%A1%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222858_22858.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222858_22858.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117703i40287443706FCAE9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222858_22858.png%22%20alt%3D%2222858_22858.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22858_22858.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13900i605A7010A521121A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_10.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%99%84%E5%8A%A0%E5%88%B0%E8%BF%90%E8%A1%8C%E7%9B%AE%E6%A0%87%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222857_22857.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222857_22857.png%22%20style%3D%22width%3A%20680px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117704iB5FD061E3E9968D8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222857_22857.png%22%20alt%3D%2222857_22857.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22857_22857.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20680px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F13901iEC0A7C36476DD9CE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E5%AF%B9%E4%BA%8E%E2%80%9C%E9%BB%91%E6%9A%97%E9%9D%A2%E7%88%B1%E5%A5%BD%E8%80%85%E2%80%9D%E6%9D%A5%E8%AF%B4%3A-)%EF%BC%9AEclipse%20Luna%E2%80%9C%E9%BB%91%E6%9A%97%E2%80%9D%E9%A3%8E%E6%A0%BC%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222860_22860.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2222860_22860.png%22%20style%3D%22width%3A%20701px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117705i20383BB215FFE521%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2222860_22860.png%22%20alt%3D%2222860_22860.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E22860_22860.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20701px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55606i6E31EAB7275B6306%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%BA%AB%E5%8F%97%20%EF%BC%9A-%EF%BC%89%3C%2FP%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Arnaldo%2C%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E9%80%9A%E8%BF%87%20Processor%20Expert%20%E9%A1%B9%E7%9B%AE%E5%8F%AF%E4%BB%A5%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erich%2C%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E2%80%9CInit_GPIO%E2%80%9D%E5%8F%AF%E4%BB%A5%E5%9C%A8%20KDS%20V3.0.0%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%E4%B8%8A%E6%8B%89%E6%88%96%E4%B8%8B%E6%8B%89%E7%94%B5%E9%98%BB%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%81%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%98%BF%E7%BA%B3%E5%B0%94%E5%A4%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%89%E7%94%A8%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20El%20Capitan%20%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E9%82%A3%E4%B9%88%E5%8F%AF%E8%83%BD%E6%98%AF%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%88%E6%9C%89%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F364331%22%20target%3D%22_blank%22%3EKDS%20on%20OS%20X%20El%20Capitan%20(Beta)%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%EF%BC%8C%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EHi%20Erich%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E6%88%91%E7%9A%84mac%E7%89%88%E6%9C%AC%E6%98%AF10.11.1%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E5%BD%93%E6%88%91%E6%89%93%E5%BC%80%20KDS%20%E5%B9%B6%E9%80%89%E6%8B%A9%E4%B8%80%E4%B8%AA%E5%B7%A5%E4%BD%9C%E5%8C%BA%E6%97%B6%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%8D%95%E5%87%BB%E4%BB%BB%E4%BD%95%E6%8C%89%E9%92%AE%E3%80%82%E5%AE%83%E8%A2%AB%E5%8D%A1%E4%BD%8F%E4%BA%86%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EKinetis%20Design%20Studio%20%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%95%86%E4%B8%9A%E7%9B%AE%E7%9A%84%EF%BC%8C%E9%99%A4%E4%BA%86%E5%8F%AA%E8%83%BD%E7%94%A8%E4%BA%8E%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E8%AE%BE%E5%A4%87%E5%A4%96%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%E9%99%90%E5%88%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%20%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%83%B3%E5%BC%80%E5%8F%91%E5%95%86%E4%B8%9A%E4%BA%A7%E5%93%81%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%94%A8%20kinetis%20studio%20%E6%9D%A5%E5%81%9A%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E5%AE%83%E6%9D%A5%E8%BE%BE%E5%88%B0%E8%BF%99%E4%B8%AA%E7%9B%AE%E7%9A%84%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E4%BB%98%E8%B4%B9%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%E6%88%91%E5%B8%8C%E6%9C%9B%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E4%BD%BF%E7%94%A8.deb%E8%80%8C%E4%B8%8D%E6%98%AF%20.bin%E7%94%A8%E4%BA%8E%20Debian%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Emv%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E.%2FKinetis%5C%20Design%5C%20Studio%5C%20installer%5C%20for%5C%20Linux%5C%2064-bit%5C%20DEB%5C%203.0.0.bin%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E.%2FKinetis%5C%20Design%5C%20Studio%5C%20installer%5C%20for%5C%20Linux%5C%2064-bit%5C%20DEB%5C%203.0.0.deb%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Esudo%20dpkg%20-i%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3E.%2FKinetis%5CDesign%5CStudio%5C%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%5Cfor%5CLinux%5C64%E4%BD%8D%5CDEB%5C3.0.0.deb%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CErich%EF%BC%8CLinux%20%E7%89%88%E6%9C%AC%20.bin%E6%97%A0%E6%B3%95%E5%AE%89%E8%A3%85%E6%96%87%E4%BB%B6%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.%2FKinetis%5C%20Design%5C%20Studio%5C%20installer%5C%20for%5C%20Linux%5C%2064-bit%5C%20DEB%5C%203.0.0.bin%20%3C%2FP%3E%3CP%3E.%2FKinetis%20Design%20Studio%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%EF%BC%88%E9%80%82%E7%94%A8%E4%BA%8E%20Linux%2064%20%E4%BD%8D%20DEB%203.0.0.bin%EF%BC%89%EF%BC%9A%E7%AC%AC%201%20%E8%A1%8C%EF%BC%9A%E6%84%8F%E5%A4%96%E6%A0%87%E8%AE%B0%E2%80%9C%E6%8D%A2%E8%A1%8C%E7%AC%A6%E2%80%9D%E9%99%84%E8%BF%91%E5%87%BA%E7%8E%B0%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3E.%2FKinetis%20Design%20Studio%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%EF%BC%88%E9%80%82%E7%94%A8%E4%BA%8E%20Linux%2064%20%E4%BD%8D%20DEB%203.0.0.bin%EF%BC%89%EF%BC%9A%E7%AC%AC%201%20%E8%A1%8C%EF%BC%9A%60!%3CARCH%3E'%3C%2FARCH%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Robert%2C%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%E6%B2%A1%E6%9C%89%E8%AE%A1%E5%88%92%E5%B0%86%20Vybrid%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20Kinetis%20Design%20Studio%E3%80%82%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20Erich%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E6%B5%81%E7%A8%8B%E4%B8%93%E5%AE%B6%E5%AF%B9%20Kinetis%20M%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erich%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20%E6%84%9F%E8%B0%A2%20MacOSX%20%E7%89%88%E6%9C%AC%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%20%E5%AF%B9%20Vybrid%20%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%E6%94%AF%E6%8C%81%E5%A6%82%E4%BD%95%EF%BC%9F%E5%AF%B9%E4%BA%8E%E7%8B%AC%E7%AB%8B%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%A5%97%E4%BB%B6%EF%BC%8C%E5%AD%98%E5%9C%A8%E4%B8%80%E4%B8%AA%20Vybrid%20%E6%8F%92%E4%BB%B6%EF%BC%8C%E6%9C%89%E4%BB%BB%E4%BD%95%E8%AE%A1%E5%88%92%E5%B0%86%E5%85%B6%E9%9B%86%E6%88%90%E5%88%B0%E6%9C%80%E6%96%B0%E7%9A%84%20KDS%2FSDK%20%E4%B8%AD%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vybrid.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Vybrid.png%22%20style%3D%22width%3A%20211px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F9008i8834B7F2AE14100C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Vybrid.png%22%20alt%3D%22Vybrid.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EVybrid.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Angus%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8A%A5%E5%91%8A%E6%AD%A4%E4%BA%8B%E3%80%82%E6%AD%A4%E9%97%AE%E9%A2%98%E5%B7%B2%E5%9C%A8%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%E7%9A%84%20Rev1%20%E7%89%88%E6%9C%AC%E4%B8%AD%E5%BE%97%E5%88%B0%E4%BF%AE%E5%A4%8D%EF%BC%88%E9%99%84%E4%BA%8E%E6%9C%AC%E9%A1%B5%EF%BC%89%E3%80%82%E5%AE%89%E8%A3%85%E9%99%84%E5%B8%A6%20Rev0%EF%BC%8C%E5%85%B6%E4%B8%AD%E7%A1%AE%E5%AE%9E%E5%AD%98%E5%9C%A8%E8%AF%A5%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Andres%2C%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8CKDS%20%E4%B8%8D%E6%94%AF%E6%8C%81%20Kinetis%20M%EF%BC%8C%E5%9B%A0%E4%B8%BA%20Kinetis%20SDK%20%E5%B0%9A%E4%B8%8D%E6%94%AF%E6%8C%81%E5%AE%83%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erich%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ekinetis%20M%20%E4%B8%8D%E6%94%AF%E6%8C%81%20kinetis%20dising%203.0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eandres%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erich%2C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%EF%BC%8C%E6%96%B0%E7%9A%84%20KDS%20%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%BE%88%E6%A3%92%EF%BC%81%E5%9C%A8%E8%AE%BF%E9%97%AE%E6%B3%A8%E5%86%8C%E8%A7%86%E5%9B%BE%E7%9A%84%E5%8F%91%E8%A1%8C%E8%AF%B4%E6%98%8E%E4%B8%AD%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BB%96%E4%BB%AC%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E2%80%9C%3CSTRONG%3E%E7%AA%97%E5%8F%A3%20%26gt%3B%20%E6%98%BE%E7%A4%BA%E8%A7%86%E5%9B%BE%20%26gt%3B%20%E5%85%B6%E4%BB%96%20%26gt%3B%20%E8%B0%83%E8%AF%95%3C%2FSTRONG%3E%E2%80%9D%E8%80%8C%E4%B8%8D%E6%98%AF%E2%80%9C%E5%B8%AE%E5%8A%A9%20%26gt%3B%20%E6%98%BE%E7%A4%BA%E8%A7%86%E5%9B%BE...%E2%80%9D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Angus%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E5%9F%83%E9%87%8C%E5%B8%8C%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Ali%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Ali%2C%3C%2FP%3E%3CP%3E%E7%BD%91%E7%BB%9C%E4%B8%8B%E8%BD%BD%E9%97%AE%E9%A2%98%E5%B7%B2%E4%BF%AE%E5%A4%8D%EF%BC%8CMac%20OS%20X%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E7%8E%B0%E5%B7%B2%E5%8F%AF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Ali%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%B9%E6%AD%A4%E8%A1%A8%E7%A4%BA%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E4%B9%9F%E6%84%8F%E8%AF%86%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%E4%B8%8E%E7%BD%91%E7%BB%9C%E5%9B%A2%E9%98%9F%E5%90%88%E4%BD%9C%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E4%BF%AE%E5%A4%8D%E5%90%8E%E5%B0%86%E5%9C%A8%E6%AD%A4%E5%A4%84%E5%8F%91%E8%A1%A8%E8%AF%84%E8%AE%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EErich%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%96%B0%20Kinetis%20Design%20Studio%20V3.0.0%20%E7%8E%B0%E5%B7%B2%E6%8E%A8%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114056%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Erich%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emac%20%E7%89%88%E6%9C%AC%E5%B7%B2%E7%BB%8F%E5%8F%AF%E7%94%A8%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKDS%20%E4%B8%8B%E8%BD%BD%E7%BD%91%E9%A1%B5%E4%B8%AD%E6%B2%A1%E6%9C%89%E9%92%88%E5%AF%B9%20Mac%20%E7%9A%84%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E9%98%BF%E9%87%8C%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kds.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kds.png%22%20style%3D%22width%3A%20755px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F49409i8374907A0087CA58%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22kds.png%22%20alt%3D%22kds.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ekds.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎05-06-2015 04:16 AM
更新人:
