Hello community!
Attached is a document that shows two methods of merging a user application and bootloader in a single file so it can be downloaded into the microcontroller at once and reduce manufacturing time and cost.
1. Merging applications using linker commands.
2. Merging applications using the P&E Advanced Flash Programming options.
I hope you can benefit from this post, if you have questions please let me know.
Best Regards!
Carlos Mendoza
