PCA85133U/2DA/Q1Z
PCA85133U/2DA/Q1Z
1,318 次查看
ppnachi
My Segment LCDs are in production from China. To choose a driver IC for the LCDs, I found a NXP part number PCA85133U/2DA/Q1Z.
This is a bare die chip. According to the datasheet it says this chip is compatible for COG fabrication. But for my application, I'm looking for a COB bare die chip.
My question is does the above mentioned part number will support for the COB fabrication? If yes I want to buy bulk quantity.
Waiting for your reply and advise
Rgds
Nazar PP
1,292 次查看
TomasVaverka
The PCA85133U/2DA/Q1Z is a bare die chip optimized for anisotropic conductive film (ACF) bonding.
As the COB fabrication typically requires a packaged IC or a bare die with suitable wire bonding and encapsulation support for mounting on a PCB, the PCA85133U/2DA/Q1Z is not suitable for that.
BRs, Tomas
1,293 次查看
TomasVaverka
BRs, Tomas
