Version 2 issues: C code generation, preview
poldo
Hi!
I started testing GUI Guider version 2, and I found a couple of issues (starting with an empty template, Windows simulator).
I started defining the content of the top layer putting an image button, creating an event handler to switch state when the button is long pressed.
The generated the code has some errors, like:
gg_event_layer_top.c:
  static void lv_layer_top()_event_handler(lv_event_t * e) {
void gg_event_init_layer_top(gg_ui_t * ui
  lv_obj_add_event_cb(ui->layer_top.lv_layer_top(),  lv_layer_top()_event_handler, LV_EVENT_ALL, ui);
(parenthesis create a parsing error)
Manually removing the parenthesis, the error below is generated:
.../generated/events/gg_event_layer_top.c:59:38: error: 'gg_layer_top_t' has no member named 'lv_layer_top'
(gg_layer_top_t definition doesn't include that member)
Am I missing some definition to make a correct generation of those functions?
poldo
Hi @Harry_Zhang .
The issue is when you create objects on the top layr. I'm attaching my file for your review and test.
meibao
This is a bug, and the fix is simple. Find your guiguider file and open it in text mode. Locate the event_list, remove any extra content, and then use the guider to reload the project. The generated code will return to normal.
poldo
Thank you, @meibao : I'll try that.
Harry_Zhang
Hi @poldo
Thanks for your project, we have reproduced this issue.
This is a bug.
We will fix it in the next version.
Thank you for your understanding.
Harry
poldo
Thank you, @Harry_Zhang .
Is there a workaround that could be used while waiting for the update?
poldo
Hi @Harry_Zhang , thank you for your reply.
This is what I did:
- On layer_top (clickable flag added, is this necessary?) I created a container for my buttons (no clickable flag added)
- Inside the container I created an image button (clickable flag added)
- I attached the event "Long Pressed" to the button
Generated code contains the syntax errors above.
// In gg_event_layer_top.c
    gg_ui_t * ui = lv_event_get_user_data(e);
    lv_event_code_t code = lv_event_get_code(e);
    switch(code) {
        default:
            break;
void gg_event_init_layer_top(gg_ui_t * ui)
    lv_obj_add_event_cb(ui->layer_top.Keypad_btnEnable, Keypad_btnEnable_event_handler, LV_EVENT_ALL, ui);
Removing the parenthesis the syntax error is about the member lv_layer_top not existing:
// In custom.h
typedef struct {
    lv_obj_t * Keypad;
    lv_obj_t * Keypad_btnEnable;
} gg_layer_top_t;
Poldo
Harry_Zhang
Hi @poldo
I tried to reproduce this issue.
The generated code is correct.
May I ask what I missed?
Harry
Harry_Zhang
Hi @poldo
May i ask how can i reproduce this issue?
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2393831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EVersion%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2393831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi!%3C%2FP%3E%3CP%3EI%20started%20testing%20GUI%20Guider%20version%202%2C%20and%20I%20found%20a%20couple%20of%20issues%20(starting%20with%20an%20empty%20template%2C%20Windows%20simulator).%3C%2FP%3E%3CP%3EI%20started%20defining%20the%20content%20of%20the%20top%20layer%20putting%20an%20image%20button%2C%20creating%20an%20event%20handler%20to%20switch%20state%20when%20the%20button%20is%20long%20pressed.%3C%2FP%3E%3CP%3EThe%20generated%20the%20code%20has%20some%20errors%2C%20like%3A%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Egg_event_layer_top.c%3A%3CBR%20%2F%3E%3C%2FFONT%3E%3CSPAN%3E%26nbsp%3B%20static%20void%20lv_layer_top()_event_handler(lv_event_t%20*%20e)%20%7B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20...%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E%20gg_event_init_layer_top%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Egg_ui_t%20%3C%2FSPAN%3E%3CSPAN%3E*%3C%2FSPAN%3E%3CSPAN%3E%20ui%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%26nbsp%3B%20lv_obj_add_event_cb(ui-%26gt%3Blayer_top.lv_layer_top()%2C%26nbsp%3B%20lv_layer_top()_event_handler%2C%20LV_EVENT_ALL%2C%20ui)%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E(parenthesis%20create%20a%20parsing%20error)%3C%2FP%3E%3CP%3EManually%20removing%20the%26nbsp%3Bparenthesis%2C%20the%20error%20below%20is%20generated%3A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E...%2Fgenerated%2Fevents%2Fgg_event_layer_top.c%3A59%3A38%3A%20error%3A%20'gg_layer_top_t'%20has%20no%20member%20named%20'lv_layer_top'%3C%2FFONT%3E%3C%2FP%3E%3CP%3E(gg_layer_top_t%20definition%20doesn't%20include%20that%20member)%3C%2FP%3E%3CP%3EAm%20I%20missing%20some%20definition%20to%20make%20a%20correct%20generation%20of%20those%20functions%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259294%22%20target%3D%22_blank%22%3E%40poldo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EMay%20i%20ask%20how%20can%20i%20reproduce%20this%20issue%3F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392057i73C2A06D3F68C4FA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1783917409079.png%22%20alt%3D%22Harry_Zhang_0-1783917409079.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1783917409079.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%26nbsp%3B%2C%20thank%20you%20for%20your%20reply.%3C%2FP%3E%3CP%3EThis%20is%20what%20I%20did%3A%3C%2FP%3E%3CP%3E-%20On%20layer_top%20(clickable%20flag%20added%2C%20is%20this%20necessary%3F)%20I%20created%20a%20container%20for%20my%20buttons%20(no%26nbsp%3Bclickable%20flag%20added)%26nbsp%3B%3CBR%20%2F%3E%3CSPAN%3E-%20Inside%20the%20container%20I%20created%20an%20image%20button%26nbsp%3B(clickable%20flag%20added)%26nbsp%3B%3CBR%20%2F%3E-%20I%20attached%20the%20event%20%22Long%20Pressed%22%20to%20the%20button%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392226iBFF783192D285B94%2Fimage-dimensions%2F885x521%3Fv%3Dv2%22%20width%3D%22885%22%20height%3D%22521%22%20role%3D%22button%22%20title%3D%22poldo_0-1784023768341.png%22%20alt%3D%22poldo_0-1784023768341.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Epoldo_0-1784023768341.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EGenerated%20code%20contains%20the%20syntax%20errors%20above.%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%2F%2F%20In%20gg_event_layer_top.c%0Astatic%20void%20lv_layer_top()_event_handler(lv_event_t%20*%20e)%0A%7B%0A%20%20%20%20gg_ui_t%20*%20ui%20%3D%20lv_event_get_user_data(e)%3B%0A%0A%20%20%20%20lv_event_code_t%20code%20%3D%20lv_event_get_code(e)%3B%0A%0A%20%20%20%20switch(code)%20%7B%0A%0A%20%20%20%20%20%20%20%20default%3A%0A%20%20%20%20%20%20%20%20%20%20%20%20break%3B%0A%20%20%20%20%7D%0A%7D%0A%0Avoid%20gg_event_init_layer_top(gg_ui_t%20*%20ui)%0A%7B%0A%20%20%20%20lv_obj_add_event_cb(ui-%26gt%3Blayer_top.lv_layer_top()%2C%20lv_layer_top()_event_handler%2C%20LV_EVENT_ALL%2C%20ui)%3B%0A%20%20%20%20lv_obj_add_event_cb(ui-%26gt%3Blayer_top.Keypad_btnEnable%2C%20Keypad_btnEnable_event_handler%2C%20LV_EVENT_ALL%2C%20ui)%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3ERemoving%20the%20parenthesis%20the%20syntax%20error%20is%20about%20the%20member%20lv_layer_top%20not%20existing%3A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3E%2F%2F%20In%20custom.h%0Atypedef%20struct%20%7B%0A%0A%20%20%20%20lv_obj_t%20*%20Keypad%3B%0A%20%20%20%20lv_obj_t%20*%20Keypad_btnEnable%3B%0A%7D%20gg_layer_top_t%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EBR%3C%2FP%3E%3CP%3EPoldo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259294%22%20target%3D%22_blank%22%3E%40poldo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20tried%20to%20reproduce%20this%20issue.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392338i96865926C7C6EACF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1784102463813.png%22%20alt%3D%22Harry_Zhang_0-1784102463813.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1784102463813.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThe%20generated%20code%20is%20correct.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392339i84E70EF53A84FFC9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_1-1784102495298.png%22%20alt%3D%22Harry_Zhang_1-1784102495298.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_1-1784102495298.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EMay%20I%20ask%20what%20I%20missed%3F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%26nbsp%3B.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20issue%20is%20when%20you%20create%20objects%20on%20the%20top%20layr.%20I'm%20attaching%20my%20file%20for%20your%20review%20and%20test.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259294%22%20target%3D%22_blank%22%3E%40poldo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20project%2C%20we%20have%20reproduced%20this%20issue.%3C%2FP%3E%0A%3CP%3EThis%20is%20a%20bug.%3C%2FP%3E%0A%3CP%3EWe%20will%20fix%20it%20in%20the%20next%20version.%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20understanding.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%26nbsp%3B.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIs%20there%20a%20workaround%20that%20could%20be%20used%20while%20waiting%20for%20the%20update%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20is%20a%20bug%2C%20and%20the%20fix%20is%20simple.%20Find%20your%20guiguider%20file%20and%20open%20it%20in%20text%20mode.%20Locate%20the%20event_list%2C%20remove%20any%20extra%20content%2C%20and%20then%20use%20the%20guider%20to%20reload%20the%20project.%20The%20generated%20code%20will%20return%20to%20normal.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410697%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410697%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265038%22%20target%3D%22_blank%22%3E%40meibao%3C%2FA%3E%26nbsp%3B%3A%20I'll%20try%20that.%3C%2FP%3E%3C%2FLINGO-BODY%3E
