GUI GUIDER 1.9.0 : create project error "download is failed"
Loic128
When I try to create a project with GUI GUIDER (1.9.0 or 1.8.1)  it finished with an error :
"Download is failed, please check your network"
Since I successed to login in GUI GUIDER, I don't think my network is the problem.
What could be the problem?
Harry_Zhang
Hi @Loic128
I haven't set up a proxy.
Can you try to change to another network?
Harry
Loic128
Hi @Harry_Zhang ,
Ok not working for me.
I will try to uninstall and reinstall.
Does it exists an offline version that don't need the network to run ?
Loic128
Still the create project error "download is failed please check your network" after uninstall reinstall.
Can we configure the proxy setting somewhere in GUI GUIDER ?
Harry_Zhang
Hi @Loic128
I disconnected the network, and the project can still be successfully created.
Harry
Loic128
Hi @Harry_Zhang ,
Thank you for your support,
Maybe the first time after install it needs to download things when create project and not after ?
If I disconnected the network I have directly the error "dowload is failed please check your network".
If I don't disconnected the network I have this error after about 20secondes.
I try to add an exception in firewall but still not works.
Maybe a proxy configuration to set ? Where can I set proxy configuration ?
Harry_Zhang
Hi @Loic128
Harry
Loic128
Hi @Harry_Zhang ,
With another connection that do not have proxy it's ok, I successfuly create the first project.
After this first project creation, I can create projects with the connection that have proxy without issue.
I think what happened with proxy connection is that I can login in GUI GUIDER with the browser window but GUI GUIDER can't download the things he need at the first project creation.
Harry_Zhang
Hi @Loic128
I tested the GUI GUider-1.9.0.
I can successfully create a project.
Please refer to the image.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2046210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGUI%20%20GUIDER%201.9.0%20%3A%20create%20project%20error%20%22download%20is%20failed%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EWhen%20I%20try%20to%20create%20a%20project%20with%20GUI%20GUIDER%20(1.9.0%20or%201.8.1)%26nbsp%3B%20it%20finished%20with%20an%20error%20%3A%3C%2FP%3E%3CP%3E%22Download%20is%20failed%2C%20please%20check%20your%20network%22%3C%2FP%3E%3CP%3ESince%20I%20successed%20to%20login%20in%20GUI%20GUIDER%2C%20I%20don't%20think%20my%20network%20is%20the%20problem.%3C%2FP%3E%3CP%3EWhat%20could%20be%20the%20problem%3F%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2050766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GUI%20%20GUIDER%201.9.0%20%3A%20create%20project%20error%20%22download%20is%20failed%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2050766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EWith%20another%20connection%20that%20do%20not%20have%20proxy%20it's%20ok%2C%20I%20successfuly%20create%20the%20first%20project.%3C%2FP%3E%3CP%3EAfter%20this%20first%20project%20creation%2C%20I%20can%20create%20projects%20with%20the%20connection%20that%20have%20proxy%20without%20issue.%3C%2FP%3E%3CP%3EI%20think%20what%20happened%20with%20proxy%20connection%20is%20that%20I%20can%20login%20in%20GUI%20GUIDER%20with%20the%20browser%20window%20but%20GUI%20GUIDER%20can't%20download%20the%20things%20he%20need%20at%20the%20first%20project%20creation.%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2048687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GUI%20%20GUIDER%201.9.0%20%3A%20create%20project%20error%20%22download%20is%20failed%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2048687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246806%22%20target%3D%22_blank%22%3E%40Loic128%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20haven't%20set%20up%20a%20proxy.%3C%2FP%3E%0A%3CP%3ECan%20you%20try%20to%20change%20to%20another%20network%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2047088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GUI%20%20GUIDER%201.9.0%20%3A%20create%20project%20error%20%22download%20is%20failed%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2047088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20support%2C%3C%2FP%3E%3CP%3EMaybe%20the%20first%20time%20after%20install%20it%20needs%20to%20download%20things%20when%20create%20project%20and%20not%20after%20%3F%3C%2FP%3E%3CP%3EIf%20I%20disconnected%20the%20network%20I%20have%20directly%20the%20error%20%22dowload%20is%20failed%20please%20check%20your%20network%22.%26nbsp%3B%3C%2FP%3E%3CP%3EIf%20I%20don't%26nbsp%3Bdisconnected%20the%20network%20I%20have%20this%20error%20after%20about%2020secondes.%3C%2FP%3E%3CP%3EI%20try%20to%20add%20an%20exception%20in%20firewall%20but%20still%20not%20works.%3C%2FP%3E%3CP%3EMaybe%20a%20proxy%20configuration%20to%20set%20%3F%20Where%20can%20I%20set%20proxy%20configuration%20%3F%3C%2FP%3E%3CP%3EThanks%2C%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GUI%20%20GUIDER%201.9.0%20%3A%20create%20project%20error%20%22download%20is%20failed%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046824%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246806%22%20target%3D%22_blank%22%3E%40Loic128%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20disconnected%20the%20network%2C%20and%20the%20project%20can%20still%20be%20successfully%20created.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1739933787755.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1739933787755.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F324640i74FF7559001CFCD1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1739933787755.png%22%20alt%3D%22Harry_Zhang_0-1739933787755.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GUI%20%20GUIDER%201.9.0%20%3A%20create%20project%20error%20%22download%20is%20failed%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EStill%20the%20create%20project%20error%20%22download%20is%20failed%20please%20check%20your%20network%22%20after%20uninstall%20reinstall.%3C%2FP%3E%3CP%3ECan%20we%20configure%20the%20proxy%20setting%20somewhere%20in%20GUI%20GUIDER%20%3F%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GUI%20%20GUIDER%201.9.0%20%3A%20create%20project%20error%20%22download%20is%20failed%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EOk%20not%20working%20for%20me.%3C%2FP%3E%3CP%3EI%20will%20try%20to%20uninstall%20and%20reinstall.%3C%2FP%3E%3CP%3EDoes%20it%20exists%20an%20offline%20version%20that%20don't%20need%20the%20network%20to%20run%20%3F%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20GUI%20%20GUIDER%201.9.0%20%3A%20create%20project%20error%20%22download%20is%20failed%22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246806%22%20target%3D%22_blank%22%3E%40Loic128%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20tested%20the%20GUI%20GUider-1.9.0.%3C%2FP%3E%0A%3CP%3EI%20can%20successfully%20create%20a%20project.%3C%2FP%3E%0A%3CP%3EPlease%20refer%20to%20the%20image.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1739874269142.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1739874269142.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F324501i843210603F45FE12%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1739874269142.png%22%20alt%3D%22Harry_Zhang_0-1739874269142.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E
