why freemaster can't open even after i filled the DLL file?
tiasum
i was installing freemaster 3.2 on my PC.At first,the warning is "can't find MFC140 DLL" "can't find VCRUNTIME140.DLL",after i download DLL files and copy to the application path,the warning changed to "0x0c00007b" and i check my PC by in put SFC/SCANNOW in commandline,it turn out that my PC is fine.is there anything wrong with the installation?or the installation pack?
MichalH
NXP Apps Support
NXP Apps Support
this is quite unexpected - all dependent libraries should be contained in the installer. Can you uninstall and try to run the installer again "As Administrator"?
There is also a way to run the system DLL installation manually. You can get the redistributable package from Microsoft directly at this link: https://aka.ms/vs/17/release/vc_redist.x86.exe. Read more at this page.
Michal
