Script error in FREEMaster when opening an old project
4,092件の閲覧回数
niclas_karlsson
When I tried to open a project from a colleague I get the script error in the picture. And then many more script errors if I click yes or no. How do I fix this?
3 返答(返信)
4,088件の閲覧回数
MichalH
NXP Apps Support
NXP Apps Support
the author of the project has probably failed to give you all project source files (HTML files and related JavaScript files). In this particular case, the jquery.min.js file is missing which is a typical file used in interactive HTML applications).
You colleague should either give you all files accompanying his project OR he may choose to pack the files into the PMP or PMPX project file. See FreeMASTER 3.0 User Guide section 5.3 for more details about resource packing.
Michal
4,076件の閲覧回数
niclas_karlsson
I can find the file in the directory. This is a file list output:
driver/
ek_qn9080xcdk.xml
frdm_ke15z.xml
frdm_ke16z.xml
NXPTouchKE15.pmp
NXPTouchKE16.pmp
NXPTouchQN9080xcdk.pmp
src/
./driver:
src_common/
./driver/src_common:
freemaster_appcmd.c
freemaster_defcfg.h
freemaster_private.h
freemaster_protocol.c
freemaster_protocol.h
freemaster_rec.c
freemaster_rec.h
freemaster_scope.c
freemaster_serial.c
freemaster_sfio.c
freemaster_tsa.c
freemaster_tsa.h
./src:
cmdhandler.js
gui.js
html_templates.js
img/
js/
json/
mustache.js
nt_control.js
nt_control_arotary.js
nt_control_aslider.js
nt_control_keypad.js
nt_control_matrix.js
nt_control_proxi.js
nt_control_rotary.js
nt_control_slider.js
nt_electrode.js
nt_electrode_afid.js
nt_electrode_safa.js
nt_electrode_usafa.js
nt_Gui.html
nt_module.js
nt_static_cfg.js
ntinit.js
static_cfg_engine.js
style.css
test1.xml
touch.min.css
touch.scss
xml_converter.js
./src/img:
cs_clk.svg
cs_controller.svg
cs_counter.svg
cs_fifo.svg
cs_int.svg
cs_oscilator.svg
cs_register.svg
cs_switch.svg
cs_switch-small.svg
detected.svg
icon-01.svg
icon-02.svg
icon-03.svg
keypad.svg
logo.svg
matrix.svg
movement.svg
popup-load.svg
proxi.svg
rotate.svg
select-dropdown-grey.ai
select-dropdown-grey.svg
slider.svg
theme-all.svg
theme-all-cs.svg
theme-all-csi.svg
triangle.svg
undetected.svg
undetected-full.svg
./src/js:
animations.js
jquery.min.js
jquery-ui.min.js
./src/json:
cycle.js
json.js
json_parse.js
json_pars
4,059件の閲覧回数
MichalH
NXP Apps Support
NXP Apps Support
the script error may also be caused by restricted Internet Explorer rights on your local computer. The Windows Internet Explorer settings affect how the HTML rendering works in the FreeMASTER. Please try the steps discussed in this post. But it is also possible, that your employer policy will not enable to run any scripts at all.
The only way would then be to migrate the Internet Explorer+ActiveX to Chromium+JSONRPC. But this would require substantial changes to page's JavaScript code.
Michal
