Re: Question on freeMASTER
1,241件の閲覧回数
medisonscott3
As i know you want open a command prompt on your computer so you can do this by pressing the Windows key, typing "Command Prompt," and selecting the Command Prompt application. Once you are in the freeMASTER directory, you can issue the START command to initiate data logging. The exact command may vary depending on the specific configuration and setup of your system. However, a common way to start logging in freeMASTER is by using the fmasterc command-line utility with the appropriate command-line arguments.
1,223件の閲覧回数
MichalH
NXP Apps Support
NXP Apps Support
please formulate a question or problem. It is hard for us to understand your issue without knowing the context. Perhaps your post has been moved to the FreeMASTER forum from another thread without preceding messages.
Also, we are not aware about a tool named "fmasterc".
Michal
