Problems with incorrect freemaster Recorder data
5,721 次查看
zyyy
freemaster had been using version 2.0 before, and later updated to version 3.0, the Recorder data became incorrect
标记 (2)
5,676 次查看
MichalH
NXP Apps Support
NXP Apps Support
by using NXP FreeMASTER with microcontrollers from other vendor you are violating FreeMASTER license conditions. You have agreed with the conditions when downloading and then also when installing the FreeMASTER.
You can only use FreeMASTER with NXP MCUs.
5,706 次查看
MichalH
NXP Apps Support
NXP Apps Support
we would need more information about the issue like:
  • Exact version of the FreeMASTER tool (the latest is 3.2.4, see Help/About)
  • What is the target MCU?
  • What communication and driver software is used at the MCU side? (the latest can be found in various SDK packages or at GitHub)
  • What do you mean by incorrect data?
Thank you,
Michal
5,677 次查看
zyyy
I am using Freemaster version 3.2.4.3
Using STM32F103 MCU
Uart communication used on MCU end
The data in Figure 3 on the left appears to be incorrect and is using version 3.0, while the data in Figure 2 on the right is normal and is using version 2.0
5,677 次查看
MichalH
NXP Apps Support
NXP Apps Support
%3CLINGO-SUB%20id%3D%22lingo-sub-2040521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFreemaster%20%E8%AE%B0%E5%BD%95%E5%99%A8%E6%95%B0%E6%8D%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2040521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Efreemaster%20%E4%B9%8B%E5%89%8D%E4%B8%80%E7%9B%B4%E7%94%A8%E7%9A%84%E6%98%AF%202.0%20%E7%89%88%E6%9C%AC%EF%BC%8C%E5%90%8E%E6%9D%A5%E6%9B%B4%E6%96%B0%E5%88%B0%203.0%20%E7%89%88%E6%9C%AC%EF%BC%8CRecorder%20%E6%95%B0%E6%8D%AE%E5%B0%B1%E4%B8%8D%E6%AD%A3%E7%A1%AE%E4%BA%86%3C%2FP%3E%3C%2FLINGO-BODY%3E
